Topic: running out of pins (Read 1 time) previous topic - next topic
mcreefer
I have an uno and this shield
http://www.dfrobot.com/wiki/index.php/Arduino_LCD_KeyPad_Shield_(SKU:_DFR0009)
And I need to dim 5 LEDs with MOSFETs via PWM. Am I stuck with using 2 arduinos or is there another way around this?
Grumpy_Mike
A link to a page with actual content would help.
You can use alternat pins for you key pad and that will free up the five out of six PWM pins you need for your LED dimming.
Alternately use a shiftbregistervto give you more pins and use shiftPwm libary to control them.
billhowl
The LCD keypad shield used
* LCD RS (Data or Signal Display Selection) pin to digital pin 8
* LCD Enable pin to digital pin 9
* LCD D4 pin to digital pin 4
* LCD D5 pin to digital pin 5
* LCD D6 pin to digital pin 6
* LCD D7 pin to digital pin 7
* Backlit Control to Digital pin 10
* Button (select, up, right, down and left) to Analog pin 0
You left with Digital 2,3,11,12,13 and Analog pin 1 to 5
You can use this TLC5940 for your LED
Grumpy_Mike
So that is 11 digital I/O. Re assign these to the shield and use the PWM for the LEDs.
No need for any other chips.
Drew Davis
Could you get an Arduino with with more pins... like the Mega?
mcreefer
For some reason the last ) is left out of the link.
I'll read more on this method since I'm stuck using an UNO and no expansion boards.
