Loading...
Pages: 1 [2] 3   Go Down
Author Topic: High speed vector graphics engine. 3.2" TFT Lcd screen.  (Read 5839 times)
North Queensland, Australia
Offline Offline
Edison Member
View Profile
WWW
I've only just finished some major improvements, and started tidying up the source. I have to work today, but over the next 2-3 days I'll try and have the first version ready. I have just embedded Henning Karlsens UTouch library into it, with a few speedups via port mapping and an additional control mode.
I'm almost finished adding rotation to the code ( why utouch was embedded, it needs to rotate as well ). By using the building blocks I've provided, it will be easy to control orientation with an accelerometer for instance, like android.
I'm going to focus on text rendering now so there is a more 'complete' release for everyone to try. But regardless of completion, I'll post something by Thursday night.
Cheers.
Logged
Finland
Offline Offline
Newbie
View Profile
Sounds great. How are you going to handle text rendering? I guess you are not going for truetype fonts.. Then maybe use utft fonts, just because they already exist and there are couple of fonts already available..
Or are you planning on going with a slimmer design for that too?
Logged
Offline Offline
Edison Member
View Profile
WWW
Quote
Yes, For now I'm going to take the easiest route for font data, utft and u8glib are my first choice for this. My main focus is getting pixels to the display as fast as possible. I've been thinking about a vector style font which would be my own interpretation of a truetype font just without control point distortion hints, or very limited hints. Even still, having a pixel map decompressed from program memory might possibly be faster.
From observation, vector style fonts may be faster for larger font sizes, as a new line algorithm that is suitable for the display can calculate multiple pixel runs, but will need a transformation to screen space. Whereas pixel maps don't need calculating but may not be able to benefit from runs.
Quote
Maybe if suitable, slimmer/smaller isn't really my goal, the design aspects of my library are selected on how well they perform. If a handful of extra bytes will increase performance dramatically, then I'll go for the larger. But don't worry, I have plans for a full config where you can select what parts are small ( code reuse ) and what parts are allowed to trade off size for speed ( specific routines for different drawing functionality).
And on a note for the future,
I also dug out my second display, which turns out to be a HX8347A?? ( TFT_320QVT ). Once the ball is rolling I may look into supporting a few other displays, however this may be an unrealistic move as my library is tailored to the SSD1289. It really seems like a few manufacturers have the monopoly on TFT production like the TV market. Same screens, different firmware/driver.
I'm gonna hit post now as lack of sleep will cause me to keep rambling on for pages. Its nice to see a lot of interest, I'm keen to see what creations people will cook up.
Logged
Offline Offline
Newbie
View Profile
I'm learning the DUE and I have just obtained a SainSmart 3.2" 320x240 TFT (with the SSD1289 driver).  Have you (or anyone) done anything with porting/testing your graphics library to the DUE from the Mega 2560?  I would guess that your code should work with a DUE without too much change.  Any code that I could download and get started with?  Thanks!
Logged
Anchorage, AK
Offline Offline
Sr. Member
View Profile
Similar note -- is this Arduino (library) specific, or would it work in GNU AVR world too?  I've put some graphic-LCD projects on the back burner because performance has always been a bit of a hindrance.  Tenfold improvements are a cool drink of water sir.
Well, well done.
Logged
Offline Offline
Newbie
View Profile
really waiting to get handle and to test that !  smiley-cool
Logged
Offline Offline
Newbie
View Profile
Hi all,
I'm also eager to see the version of pYro_65.
In the meantime, here is a simple method for optimizing (a little bit) the current version: First download the latest version from the site "henningkarlsen" which dates from January 2013 and contains some optimizations,
then remove all the tests on display_transfer_mode especially in methods such as LCD_Writ_Bus or LCD_Write_COM.
For example, my LCD_Writ_Bus method :
void UTFT::LCD_Writ_Bus(char VH,char VL)
  PORTA = VH;
  PORTC = VL;
  pulse_low(P_WR, B_WR);
With this modification, some methods are twice as fast : drawpixel (100µs instead of 200µs), print, DrawBitmap, DrawLine, etc.
Of course my TFT version only works with screen SSD1289 but no problem since it is the only one I have.
This is far from what announces pYro_65 but in the meantime it helps.
Logged
Offline Offline
Newbie
View Profile
hi mael,
already done on my side to clean all the unnecessary code in UTFT  smiley-grin
but still far of what this post promise .
Logged
Offline Offline
Newbie
View Profile
news?
Logged
Offline Offline
Newbie
View Profile
news?
Some news ????
I'm waiting for this "Library Mod" !!  smiley-cool
Logged
Offline Offline
Newbie
View Profile
dead
Logged
France
Offline Offline
God Member
Scientia potentia est.
View Profile
pYro, you gave up, or.. ? smiley-kitty
Logged
Offline Offline
Newbie
View Profile
hi mael,
Hi Vincent13,
I coded a workbench to compare my optimizations with the original version.
Here are my results :
Code:
start...
Initial version time - optimized version time - opération
724576 us     - 37248 us   : clrScr
200 us        - 24 us      : DrawPixel
2020 us       - 232 us     : DrawPixel x 10
4 us          - 4          : SetColor
4 us          - 4          : SetBackColor
19856 us      - 5804 us    : FillRoundRect 40x40
2652 us       - 636 us     : DrawRoundRect 40x40
4928 us       - 916 us     : drawLine 40x40
604 us        - 152 us     : draw Vertical Line 40
612 us        - 144 us     : draw Horizontal Line 40
27836 us      - 1480 us    : FillRect 40x40
8 us          - 8          : SetSmallFont
7764 us       - 2300 us    : Print 001
7640 us       - 2300 us    : Print Abc
7892 us       - 2580 us    : printNumI(123)
8 us          - 8          : SetBigFont
14912 us      - 4332 us    : Print 001
15048 us      - 4424 us    : printNumI(123)
11668 us      - 2412 us    : draw bitmap 32x32
Do you have better results ? (do you want my WorkBench sketch ?)
Logged
Netherlands
Offline Offline
Tesla Member
In theory there is no difference between theory and practice, however in practice there are many...
View Profile
Quite impressive numbers here!   Well done!
Logged
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
Offline Offline
Newbie
View Profile
yep why not compare smiley-wink
give me access to your bench code using mp  smiley-sweat
Logged
Pages: 1 [2] 3   Go Up
Print
Jump to:
