Topic: For Help -> one Arduino to read several ADXL345s (Read 973 times) previous topic - next topic
ruan-qiang
Recently I'm on a project that I need to read several ADXL345s . So how can I make it with just one microcontroller, such as uno or 2560 ?
tuxduino
IIRC it's an I2C chip, so you can connect many on the same bus (on Arduino UNO i2c pins are A4 and A5, but please don't take my word for it, check the shematics).
AWOL
Without extra hardware, or software I2C, you can only have two of these connected at one time, because you have only two possible addresses.
"Pete, it's a fool looks for logic in the chambers of the human heart." Ulysses Everett McGill.
Do not send technical questions via personal messaging - they will be ignored.
ruan-qiang
Thank you ~~
but…I'm just not very familiar with ADXL345, what do you mean by "2 addresses"?
I knew one is 0x53 (am I right?), and what is the other address?
or is there some Software IIC library that can be downloaded?
AWOL
In I2C mode, the CE pin (chip enable) is the address select pin, and gives you one alternate address.
The other value will be in the data sheet.
ruan-qiang
Thank you for the advises~~~I'll learn more from the datasheet later
