Topic: time clock module.. (Read 2541 times) previous topic - next topic
Ruffsta
i bought this for my son, but we cannot find any tutorials or anything else he needs to use it...
found this, but it's not the same..
http://combustory.com/wiki/index.php/RTC1307_-_Real_Time_Clock
thanks in advance
tuxduino
The Time library has good support for DS1307.
http://playground.arduino.cc/Code/Time
nickgammon
I would connect up SDA, SCL, 5V, and Gnd as described in that article and saw what happened.
More info:
NickPyner
#3
Jan 02, 2013, 01:06 am Last Edit: Jan 02, 2013, 01:32 am by NickPyner Reason: 1
The clocks are the same, they just look different. I have the blue one just like yours. I had as seriously bad time getting any joy from it. This was partly due to my being a newbie, but far from wholly. I believe there is a swag of confusing and out-of-date junk out there - and badly written too. Since you ask the question, I assume you two are newbies. Being a newbie puts you at the disadvantage of having the latest gear, thereby having to sort the wheat from the chaff, and quite a lot of that chaff is in the Arduino playground.
About the only decent up-to-date tutorial written for the  DS1307 is here
http://bildr.org/2011/03/ds1307-arduino/
Read the first line in the code twice, indeed they write it twice.
You only need four wires. Most of the terminals on the blue board are duplicates and it doesn't matter which one you use.
There are two sketches, one for setting the clock and the other for running. You write the setting time in the first sketch and the start point is when you release the reset button. Needless to say, the two sketches can be merged if you wish, and it might be an interesting programming exercise involving serial read, but I haven't bothered. My module came running on Shanghai Time.
tuxduino
The Time library takes care of communication with the DS1307 for you. Highly recommended.
CrossRoads
You have 2 chips on the I2C bus there - the DS1307, and a Atmel 24C32 EEPROM.
http://datasheets.maximintegrated.com/en/ds/DS1307.pdf
http://www.atmel.com/Images/doc0336.pdf
Both are addressed individually.
projectstowork1
May I ask what is the purpose of adding the 24c32 for the ds1307 chip?
Boffin1
I have used part of the 56k of the DS1307s  nv memory ok, but I guess there might be projects that need more ?
45 years of editing projects with a knife and soldering iron, then I found Arduino !
AWOL
bytes
Jack Christensen
Typical data logging setup. Memory to store the data and an RTC to time the sampling.
projectstowork1
Boffin1
bytes of course :-)
