Topic: Servo stops suddenly? (Read 2691 times) previous topic - next topic
HackWar
Jan 01, 2013, 09:15 pm Last Edit: Jan 01, 2013, 09:36 pm by HackWar Reason: 1
I'm trying to convert my parallax Boe Bot into a Arduino Due version. Unfortunately I'm running into something I cannot explain. The servos start to rotate as expected, but after a few seconds the right servo just stops while the other one keeps running. I cannot find a reason for this, even the 'rightServo.read()' tells me it's running at full speed. What could be the cause of this? I've unplugged the USB connection and connected it to a wall outlet but the results are the same.
http://i49.tinypic.com/2nlbc51.jpg
#include <Servo.h>
Servo pingServo;
Servo leftServo;
Servo rightServo;
int pos = 90;    // variable to store the servo position
boolean countUpwards = true;
unsigned long currentTime;
unsigned long loopTime;
const int PIN_PING_SERVO = 8;
const int PIN_LEFT_SERVO = 10;
const int PIN_RIGHT_SERVO = 9;
const int PIN_PING = 31;
const int PIN_PUSH_BUTTON = 53;
int distancesByAngle[] = {};
int distance = 999;
int oldButtonState = 0;
boolean buttonPressed = false;
boolean programActive = false;
 pinMode(PIN_LEFT_SERVO, OUTPUT);
 pinMode(PIN_RIGHT_SERVO, OUTPUT);
 pinMode(PIN_PUSH_BUTTON, INPUT);
 pingServo.attach(PIN_PING_SERVO);
 leftServo.attach(PIN_LEFT_SERVO);
 rightServo.attach(PIN_RIGHT_SERVO);
 pingServo.write(pos);
 leftServo.write(90);
 rightServo.write(90);
 int buttonState = digitalRead(PIN_PUSH_BUTTON);
 currentTime = millis();
 if(currentTime >= (loopTime + 500)){
   if(countUpwards){
     pos = pos + 20;
     if(pos>=170){
       countUpwards = false;
   }else{
     pos = pos - 20;
     if(pos<=10){
   distance = checkDistance();
   //pingServo.write(pos);
   distancesByAngle[pos] = distance;
   if(distance<30){
     moveRight();
   loopTime = currentTime;  // Updates loopTime
 moveForward();
 oldButtonState = buttonState;
long checkDistance(){
 // establish variables for duration of the ping,
 // and the distance result in inches and centimeters:
 long duration, cm;
 // The PING))) is triggered by a HIGH pulse of 2 or more microseconds.
 // Give a short LOW pulse beforehand to ensure a clean HIGH pulse:
 pinMode(PIN_PING, OUTPUT);
 digitalWrite(PIN_PING, LOW);
 delayMicroseconds(2);
 digitalWrite(PIN_PING, HIGH);
 delayMicroseconds(5);
 pinMode(PIN_PING, INPUT);
 duration = pulseIn(PIN_PING, HIGH);
 cm = microsecondsToCentimeters(duration);
 //Serial.print(cm);
 //Serial.print("cm on pos: ");
 //Serial.print(pos);
 //Serial.println();
 return cm;
void fullStop(){
 //Serial.println("FULL STOP");
 pingServo.write(90);
 delay(15);
void moveForward(){
 //Serial.println("FORWARD");
 rightServo.write(0);
 leftServo.write(180);
 delay(15);
 Serial.print("rightServo: ");
 Serial.print(rightServo.read());
 Serial.print(", leftServo: ");
 Serial.print(leftServo.read());
 Serial.println();
void moveRight(){
 //Serial.println("RIGHT");
 delay(15);
long microsecondsToCentimeters(long microseconds)
 return microseconds / 29 / 2;
DuaneB
from your description and picture I cannot see thatnyou have a separate power source for the servos, if not try this as a solution - check th btwo links in my signature for more details.
Duane B
rcarduino.blogspot.com
Read this
http://rcarduino.blogspot.com/2012/04/servo-problems-with-arduino-part-1.html
then watch this
http://rcarduino.blogspot.com/2012/04/servo-problems-part-2-demonstration.html
Rcarduino.blogspot.com
Grumpy_Mike
You probably need decoupling on the supply. It sounds like the interference from the motor is screwing with the code.
HackWar
Ah now it's starting to make sense, I thought the the external power connector on the board would be the decoupled power source, but obviously it's not. So if I set my wall wart to 5V and connect it to my breadboard and power the servo's from there it should work right?
JimboZA
Since I followed your servo tutorial link Duane, in the last two days I've pointed 2-3 members there. It explains stuff really clearly, thanks.
Johannesburg hams call me: ZS6JMB on Highveld rep 145.7875 (-600 & 88.5 tone)
Dr Perry Cox: "Help me to help you, help me to help you...."
Your answer may already be here: https://forum.arduino.cc/index.php?topic=384198.0
Grumpy_Mike
Motors tend to need more decoupling than most other components:-
http://www.thebox.myzen.co.uk/Tutorial/De-coupling.html
