Loading...
Pages: [1] 2   Go Down
Author Topic: Moving analog data over serial  (Read 524 times)
Offline Offline
Newbie
View Profile
I need to move the analog data from the input pins on one arduino to another arduino over the serial port. I am able to get the analog data going out the serial port of the "transmitter" arduino and I have connected the tx output of the transmitter to the rx of the reciever. But I cannot get the data to the reciever.
Here is the transmitter program
Code:
int  bcd1 = 2;
int  bcd2 = 3;
int  bcd4 = 4;
int  bcd8 = 5;
int  analogpinred = 0;
int  analogpingreen = 1;
int  analogpinblue = 2;
int  analogpinamber = 3;
int  analogpinpink = 4;
int  red = 0;
int  green = 0;
int  blue = 0;
int  amber = 0;
int  pink = 0;
int  valuecmd = 0;
void setup ()
pinMode  (bcd1, INPUT);
digitalWrite (bcd1, HIGH);
pinMode  (bcd2, INPUT);
digitalWrite  (bcd2, HIGH);
pinMode  (bcd4, INPUT);
digitalWrite (bcd4, HIGH);
pinMode  (bcd8, INPUT);
digitalWrite (bcd8, HIGH);
void loop ()
readanalog ();
buildbcd ();
serialoutput ();
void  readanalog ()
  red = analogRead(analogpinred);
  green = analogRead(analogpingreen);
  blue = analogRead(analogpinblue);
  amber = analogRead(analogpinamber);
  pink = analogRead(analogpinpink);
void  buildbcd ()
  valuecmd = 0;
  if (digitalRead(bcd1) == LOW)
    valuecmd = valuecmd + 1;
  if (digitalRead(bcd2) == LOW)
    valuecmd = valuecmd + 2;
  if (digitalRead(bcd4) == LOW)
    valuecmd = valuecmd + 4;
  if (digitalRead(bcd8) == LOW)
    valuecmd = valuecmd + 8;
void serialoutput ()
  Serial.print(red);
  Serial.print(",");
  Serial.print(green);
  Serial.print(",");
  Serial.print(blue);
  Serial.print(",");
  Serial.print(amber);
  Serial.print(",");
  Serial.print(pink);
  Serial.print(",");
  Serial.print(valuecmd);
  Serial.println("");
and here is the reciever program
Code:
int  redpin = 2;
int  greenpin = 5;
int  bluepin = 6;
int  amberpin = 9;
int  pinkpin = 10;
int  outA = 2;
int  outB = 4;
int  outC = 7;
int  outD = 8;
int  outE = 11;
int  outF = 12;
int  outG = 13;
int  red = 0;
int  green = 0;
int  blue = 0;
int  amber = 0;
int  pink = 0;
int  valuecmd = 0;
void setup ()
pinMode (redpin, OUTPUT);
pinMode (greenpin, OUTPUT);
pinMode (bluepin, OUTPUT);
pinMode (amberpin, OUTPUT);
pinMode (pinkpin, OUTPUT);
pinMode (outA, OUTPUT);
pinMode (outB, OUTPUT);
pinMode (outC, OUTPUT);
pinMode (outD, OUTPUT);
pinMode (outE, OUTPUT);
pinMode (outF, OUTPUT);
void loop ()
readserial ();
printserial ();
void  readserial ()
  while (Serial.available() > 0)
    red = Serial.parseInt();
    green = Serial.parseInt();
    blue = Serial.parseInt();
    amber = Serial.parseInt();
    pink = Serial.parseInt();
    valuecmd = Serial.parseInt();
    if (Serial.read() == '\n')
      output128 ();
      output64 ();
      output32 ();
      output16 ();
      output8 ();
      output4 ();
      output2 ();
      output1 ();
void output128 ()
  if (valuecmd > 127)
    valuecmd = valuecmd - 128;
    digitalWrite (outA, HIGH);
    digitalWrite (outA, LOW);
void output64 ()
  if (valuecmd > 637)
    valuecmd = valuecmd - 64;
    digitalWrite (outB, HIGH);
    digitalWrite (outB, LOW);
void output32 ()
  if (valuecmd > 31)
    valuecmd = valuecmd - 32;
    digitalWrite (outC, HIGH);
    digitalWrite (outC, LOW);
void output16 ()
  if (valuecmd > 15)
    valuecmd = valuecmd - 16;
    digitalWrite (outD, HIGH);
    digitalWrite (outD, LOW);
void output8 ()
  if (valuecmd > 7)
    valuecmd = valuecmd - 8;
    digitalWrite (outE, HIGH);
    digitalWrite (outE, LOW);
void output4 ()
  if (valuecmd > 3)
    valuecmd = valuecmd - 4;
    digitalWrite (outF, HIGH);
    digitalWrite (outF, LOW);
void output2 ()
  if (valuecmd > 1)
    valuecmd = valuecmd - 2;
void output1 ()
  if (valuecmd > 0)
    analogWrite (redpin, red);
    analogWrite (greenpin, green);
    analogWrite (bluepin, blue);
    analogWrite (amberpin, amber);
    analogWrite (pinkpin, pink);
    analogWrite (redpin, 0);
    analogWrite (greenpin, 0);
    analogWrite (bluepin, 0);
    analogWrite (amberpin, 0);
    analogWrite (pinkpin, 0);
void printserial ()
  Serial.print (red);
  Serial.print (",");
  Serial.print (green);
  Serial.print (",");
  Serial.print (blue);
  Serial.print (",");
  Serial.print (amber);
  Serial.print (",");
  Serial.print (pink);
  Serial.print (",");
  Serial.print (valuecmd);
  Serial.print ("\n");
Any ideas what I am doing wrong here. Basically I am trying to move 6 values in a comma delimited format over the serial ports from one arduino to another.
Thanks for any input
Jim
Moderator edit: [code] [/code] tags added.
« Last Edit: January 01, 2013, 04:41:54 pm by Coding Badly » Logged
Manchester (England England)
Offline Offline
Brattain Member
Solder is electric glue
View Profile
WWW
Quote
Yes you are not using the correct code tabs.
READ THIS:-
http://arduino.cc/forum/index.php/topic,97455.0.html
Logged
Copenhagen / Denmark
Offline Offline
Edison Member
Do it !
View Profile
WWW
Did you remember to connect the grounds of the two Arduino boards ?
Logged
0
Offline Offline
God Member
Get Bitlash: http://bitlash.net
View Profile
If you are using two standard Arduinos with on-board USB hardware, it does not work to connect an additional TX input to the RX pin.  It fights with the existing connection to the USB hardware on that pin.
You can use another pin as a serial input on the receiving unit with the SoftSerial library.  Search the forum and playground for examples.
Good luck with your project,
-br
Logged
Offline Offline
Newbie
View Profile
Yes grounds are connected.  The boards I am using do not have USB on them.
Logged
0
Offline Offline
God Member
View Profile
Does the receiver work as expected when you type the expected input to it in the serial monitor while it's connected to a PC?
-br
Edit: an additional question: doesn't parseInt() leave the delimiter as the next available character in the serial buffer?  If so, wouldn't you have to eat the comma with Serial.read() after parseInt() to move on past the comma?
« Last Edit: January 01, 2013, 04:41:34 pm by billroy » Logged
Offline Offline
Newbie
View Profile
Yes it does. Apparently the voltage levels on the pins 0 and 1 do not work for ttl. Rs232. When I jumper the tx pin on the header going to the Macintosh USB cable header on the arduino board to the Rex pin on the programming port on the reciever board the signal get there okay.
What kind of circuit do I have to use to get the pins 0 and 1 to have the correct voltage levels to communicate.
Logged
0
Offline Offline
God Member
View Profile
If the two arduinos are running at the same +VCC, a direct connection from TX on Arduino 1 to Rx on Arduino 2 should "just work" for 9600 baud serial, provided nothing else is connected to the either pin in question, and the grounds are good.
A puzzler...
-br
Logged
Left Coast, CA (USA)
Offline Offline
Brattain Member
Measurement changes behavior
View Profile
-br
No, the arduino boards uses two 1K ohm 'isolation' resistors on the send and rec lines from pins 0 and 1 to the USB serial converter chip. As long as you are not receiving data from the PC via USB (or better yet not plugged into USB) you can directly connect pins 0 and 1 to another arduino boards pin 1 and 0 and exchange serial data with each other.
Lefty
Logged
0
Offline Offline
God Member
View Profile
Thanks, Lefty.  Happy to know that.
-br
Logged
Offline Offline
Brattain Member
View Profile
WWW
Code:
So if there is only one byte in the serial buffer you happily go off and read lots of data from the serial port. Spot your error?
Logged
Offline Offline
Newbie
View Profile
No. I don't even understand this. I am using an exact copy of a way to read a serial buffer from an example on the auduino web site.
Logged
California
Online Online
Edison Member
View Profile
Which example?
Logged
Offline Offline
Brattain Member
View Profile
WWW
Exactly because either you are missunderstanding it or it is wrong.
Serial data takes a long time to arrive, just because one byte has arrived does not mean that all the bytes have arrived. FACT.
Logged
Seattle, WA USA
Online Online
Brattain Member
Seattle, WA USA
View Profile
Change your sender:
  Serial.print("<");
  Serial.print(red);
  Serial.print(",");
  Serial.print(",");
  Serial.print(blue);
  Serial.print(",");
  Serial.print(",");
  Serial.print(pink);
  Serial.print(",");
  Serial.println(">");
Use code like this on the receiver:
Code:
#define SOP '<'
#define EOP '>'
bool started = false;
bool ended = false;
char inData[80];
byte index;
   Serial.begin(57600);
   // Other stuff...
  // Read all serial data available, as fast as possible
  while(Serial.available() > 0)
    char inChar = Serial.read();
    if(inChar == SOP)
       index = 0;
       inData[index] = '\0';
       started = true;
       ended = false;
    else if(inChar == EOP)
       ended = true;
      if(index < 79)
        inData[index] = inChar;
        index++;
  // We are here either because all pending serial
  // data has been read OR because an end of
  // packet marker arrived. Which is it?
  if(started && ended)
    // The end of packet marker arrived. Process the packet
    // Reset for the next packet
    started = false;
    ended = false;
    index = 0;
Where it says "Process the packet", use strtok() and atoi() to get the numbers from inData.
Logged
Pages: [1] 2   Go Up
Print
Jump to:
