Loading...
Pages: 1 [2]   Go Down
Author Topic: Moving analog data over serial  (Read 518 times)
Global Moderator
UK
Offline Offline
Brattain Member
I don't think you connected the grounds, Dave.
View Profile
Code:
void output64 ()
  if (valuecmd > 637)
Novel.
Can I recommend you revise your binary arithmetic?
Logged
Pete, it's a fool looks for logic in the chambers of the human heart.
Offline Offline
Newbie
View Profile
The example I was using is from the web site.
http://arduino.cc/en/Tutorial/ReadASCIIString
Logged
Manchester (England England)
Online Online
Brattain Member
Solder is electric glue
View Profile
WWW
Yep looks like crap code in that link.
Logged
Leeds, UK
Offline Offline
God Member
Once the magic blue smoke is released, it won't go back in!
View Profile
WWW
It isn't partuclarly crap. "parseInt()" sits there trying to read in values from the Serial port until it either times out (and returns 0), or another character arrives in and it sits there trying to read the next. That means that it doesn't need for Serial.available() to be any more than 1 when you first call it for it to work.
Granted the implementation could be improved, for example, if you send "12-34" it will detect it as -1234, and if it takes too long for the 2nd, 3rd, and so on characters to arrive after each other it will just give up and return.
Also that example doesn't account for the fact that you should wait until Serial.available()>0 in between each of the calls to parseInt().
« Last Edit: January 07, 2013, 05:24:24 pm by Tom Carpenter » Logged
~Tom~
Left Coast, CA (USA)
Offline Offline
Brattain Member
Measurement changes behavior
View Profile
Exactly because either you are missunderstanding it or it is wrong.
Serial data takes a long time to arrive, just because one byte has arrived does not mean that all the bytes have arrived. FACT.
LOL, otherwise they wouldn't be allowed to call it serial data as it would be a violation of truth in advertising. Not unlike the fundamental difference between a serial killer and a mass killer, unless you are a victim where the difference is somewhat moot.
Lefty
« Last Edit: January 07, 2013, 08:38:40 pm by retrolefty » Logged
Offline Offline
Newbie
View Profile
I found the binary math problem later. Doesn't help the speed any but did fix the logic.
Logged
Pages: 1 [2]   Go Up
Print
Jump to:
