Offline
Newbie
« on: January 01, 2013, 10:25:03 am » |
Hello, This is my first post here, i am working on a project that involves a Pi and a ardunio UNO (the Pi communicates with UNO via the serial over USB connection). The final device has to run off of a 7.6v battery, i have tested this and the ardunio + servos + speed controllers can all operate together well while running on the battery. However I am having issues determining the best way of powering the Pi. I know that the UNO has a 5v pin that (from some reading) should be able to supply a maximum of between 500-700mA, I am unsure of any damage that can happen when powering the Pi from the UNO and then connecting the Pi to the UNO via USB. Any advice would be greatly appreciated p.s. I hope this is the correct forum for this
Logged
North Queensland, Australia
Offline
Edison Member
« Reply #1 on: January 01, 2013, 10:32:59 am » |
If you have a large enough power supply, I would run a separate regulator for the pi, I thought the Arduino maxed out at around 300ma. Either way the onboard regulator will become inefficient at a high load.
Logged
Johannesburg UTC+2
Offline
Edison Member
« Reply #2 on: January 01, 2013, 10:44:04 am » |
run off of a 7.6v battery I'm interested to know, Apache, what battery you use please?
Logged
IT Crowd: Roy... "Have you tried turning it off and on again?" Moss.. "Have you tried forcing an unexpected reboot?"
Offline
Newbie
« Reply #3 on: January 01, 2013, 10:56:04 am » |
run off of a 7.6v battery I'm interested to know, Apache, what battery you use please? Sorry that was a typo its a 7.4v Li-Po battery, i think its from an old RC plane. Sorry for any confusion If you have a large enough power supply, I would run a separate regulator for the pi, I thought the Arduino maxed out at around 300ma. Either way the onboard regulator will become inefficient at a high load.
Yeah any recommendations for a good regulator ? i was looking at the TS7805 (1A 5V) as its available from maplin
Logged
Johannesburg UTC+2
Offline
Edison Member
« Reply #4 on: January 01, 2013, 11:01:08 am » |
Sorry for any confusion Haha no I wasn't confused! It was a genuine question because I'm looking for a sensible source of energy for a robot arm. 7.6V made just as much sense to me as 8.5 or 6.3 or any other random pair of digits!
Logged
Offline
Newbie
« Reply #5 on: January 01, 2013, 11:06:39 am » |
Sorry for any confusion Haha no I wasn't confused! It was a genuine question because I'm looking for a sensible source of energy for a robot arm. 7.6V made just as much sense to me as 8.5 or 6.3 or any other random pair of digits! Specifically the battery is a PKZ1032
Logged
Manchester (England England)
Offline
Brattain Member
Solder is electric glue
« Reply #6 on: January 01, 2013, 03:45:44 pm » |
I know that the UNO has a 5v pin that (from some reading) should be able to supply a maximum of between 500-700mA, No it can't. It is limited by the power dissipation of the regulator:- http://www.thebox.myzen.co.uk/Tutorial/Power_Examples.html
Logged
Ayer, Massachusetts, USA
Offline
Edison Member
« Reply #7 on: January 01, 2013, 09:10:03 pm » |
IIRC, the Pi needs at least 5 volts and 800 maH, and so the Arduino would not be able to drive it directly. When the Pi's first came out, there was a scramble to find wall warts and USB hubs that provided enough power (the latest generation of smart phones and tablets wanting more than the 500 maH for fast charging has meant it is now easier to find 1 amp and 2.1 amp wall warts, though it would be nice if wall warts with multiple plugs could provide 2.1 amps to each plug, rather than dividing it among the devices).
« Last Edit: January 01, 2013, 09:20:25 pm by MichaelMeissner »
Logged
Offline
Edison Member
« Reply #8 on: January 01, 2013, 09:26:22 pm » |
IIRC, the common lithium cell in a lot of batteries delivers 3.7 volts. So if internally the battery has 2 cells in parallel, it would deliver 7.4 volts (11.1 volts if the battery has 3 cells in parallel). Nimh batteries like AA rechargeables tend to deliver 1.2 volts, so 3 AA rechargeable batteries would be 3.6 volts, 6 would be 7.2 volts, etc. Of course batteries often times deliver voltage in a range, rather than being a specific value.
Logged
Darlington, UK
Offline
Full Member
53B in Transition
« Reply #9 on: January 02, 2013, 09:09:24 am » |
A very cost effective method for powering a pi is using a UBEC http://www.hobbyking.com/hobbyking/store/__14310__HobbyKing_UBEC_3A_2_6s_LiPO.html#relprodspan_focusYou can select 5 or 6 volt output up to 3amp draw, so perfect for a pi. It'll draw power from 2S (7.4 volts) up to 6S (22.2 volts) DC source, so perfect for most hobby style LiPo batteries. You will need to solder some terminals and possibly reconfigure the it put, the white wire is. Signal wire, btw, so you won't need that. You can either just chop it out or ignore it.
Logged
