Topic: Voltage divider problem (Read 22610 times) previous topic - next topic
Boopidoo
Yes, maybe. Do you have some ideas on such chips that I could use with the Arduino?
dhenry
Put a small capacitor on the analog input pin. Anything from 0.1n to 1000n will work.
The issue is that your input resistance is too high.
retrolefty
Here are two nice ones that adafruit sells:
12 bit ADC https://www.adafruit.com/products/1083
16 bit ADC https://www.adafruit.com/products/1085
I've got a ADS1115 module from an e-bay firm and was quite impressed with it's features and capabilities.
Lefty
oric_dan
What are the resistor tolerances on those adafruit devices?
Where they say 12 or 16-bit "precision", they actually mean resolution, and not accuracy.
You might be able to discriminate 1 part in 4096 or 65536, but the absolute value may
still be off by 5%, or 204  parts in 4096, or 3276 parts in 65536.
retrolefty
The total word size (bits) determine the steps of resolution possible, the accuracy depends on the reference voltage used and of course the quality of the internal design of the chip. Both those models have an internal voltage reference as well as programmable gain settings, 4 single ended input channels or 2 differential input channels. The datasheet shows all the possible error tolerances and are impressive if you study ADC chips in the past. It's not a cheap chip but certainly a very powerful feature filled chip. Study the datasheet at your leisure.
http://www.ti.com/lit/ds/symlink/ads1115.pdf
oric_dan
Ah so, I misinterpreted the ckt, and thought those smt resistors had to do
with gain-setting or voltage dividers. However, the d/s uses the word resolution,
and doesn't confuse with precision.
http://en.wikipedia.org/wiki/Accuracy_and_precision
I guess the accuracy would be wrapped up in the values of,
Integral nonlinearity DR = 8SPS, FS = ±2.048V, best fit(2) 1 LSB
FS = ±2.048V, differential inputs ±1 ±3 LSB
Offset error
FS = ±2.048V, single-ended inputs ±3 LSB
Offset drift FS = ±2.048V 0.005 LSB/°C
Offset power-supply rejection FS = ±2.048V 1 LSB/V
Gain error(3) FS = ±2.048V at 25°C 0.01 0.15 %
FS = ±0.256V 7 ppm/°C
Gain drift(3) FS = ±2.048V 5 40 ppm/°C
FS = ±6.144V(1) 5 ppm/°C
Gain power-supply rejection 80 ppm/V
PGA gain match(3) Match between any two PGA gains 0.02 0.1 %
Gain match Match between any two inputs 0.05 0.1 %
Offset match Match between any two inputs 3 LSB
At dc and FS = ±0.256V 105 dB
At dc and FS = ±2.048V 100 dB
Common-mode rejection At dc and FS = ±6.144V(1) 90 dB
retrolefty
#36
Jan 04, 2013, 12:06 am Last Edit: Jan 04, 2013, 12:17 am by retrolefty Reason: 1
At the refinery I worked at before retirement we dealt with a lot of calibration issues and training. We tried to teach two different concepts to new instrumentation techs that started work there about what a quality measurement was and was not.
If a sensor can be proved to have good 'repeatablity' within it's rated 'accuracy' over it's full measurement range then you have a good sensor, stop fussing with it. Absolute accuracy is all about standards and what you are using as a reference to compare all other readings with. We stressed about repairs and adjustments that ended up with good repeatablity, rather then the circular fool's path of 'proving' that a given measurement is 'accurate'. So we used the word repeatablity to mean precision and didn't pretend to claim anything about accuracy.
On a few legal compliance measurements that local government required for us to have official calibration standards traceable to an approved 3rd party lab standards. For those we had to send out a few of our "bench standards instruments" such as a couple of bench DMM, bench deadweight tester (used for pressure measurements), bench electronic pressure sensor, etc to an 'approved' calibration laboratory which would test our standards, publish accuracy specs for them and put a dated seal on them good for one year. With these 'bench standards' we could then use them to compare our other measurement equipment when dealing with compliance measurement issues.
The word accuracy is a very overloaded word that can mean many different things to many different people. In principal it would seem to be a simple word, how close is a specific measurement to it's 'true' value. The problem is defining 'true' and trying to implement it in a meaningful, useful, and practical matter. Metrology can be an incredibly complex field. It's also incredibly expensive.  :D
http://en.wikipedia.org/wiki/Metrology
Boopidoo
#37
Jan 04, 2013, 12:29 am Last Edit: Jan 04, 2013, 02:59 pm by Boopidoo Reason: 1
Well, now I've tried to try a few things in my code and have some interesting results. However I'm not done and will test this in various temperatures next.
In the following code I use three methods. All of them uses the same voltage divider so changes due to resistor tolerances and temperature change will be the same for all.
Method 1 is using the code from retrolefty.
Method 2 is using the code from Scott Daniels. This one suggests a method of calibrating which I've done: http://provideyourown.com/2012/secret-arduino-voltmeter-measure-battery-voltage/
Method 3 is just using 5V without bothering to know about reference voltage etc.
Powering using USB:
4.52V (measured using my meter)
4.44V (method 1) diff 1.8%
4.51V (method 2) diff 0.2%
4.45V (method 3) diff 1.5%
Powering usning 3S:
11.62V (measured using my meter)
11.46V (method 1) diff 1.5%
11.62V (method 2) diff 0.0%
11.61V (method 3) diff 0.1%
Code: [Select]
// Boopidoo Ground Station
#include <LiquidCrystal.h>
//LCD display pinout - YM2004A & OV1604A
//VSS   LCD pin 1     -  Connect to ground
//VDD   LCD pin 2     -  Connect to +5V
//V0    LCD pin 3     -  Connect to potentiometer
//RS    LCD pin 4     -  Arduino pin D07
//RW    LCD pin 5     -  Connect to ground
//EN    LCD pin 6     -  Arduino pin D08
//DB4   LCD pin 11    -  Arduino pin D09
//DB5   LCD pin 12    -  Arduino pin D10
//DB6   LCD pin 13    -  Arduino pin D11
//DB7   LCD pin 14    -  Arduino pin D12
//ELA   LCD pin 15    -  Arduino pin D13
//ELK   LCD pin 16    -  Connect to ground
//LiquidCrystal lcd(7, NULL, 8, 9, 10, 11, 12);
LiquidCrystal lcd(7, 8, 9, 10, 11, 12);
int screen_backlight = 13;                       //pin D13 will control the backlight
float voltage_battery1 = 0.0;                    //voltage from pin A0
float voltage_reference1 = 0.0;                  //reference voltage on the arduino 5V-rail
float voltage_battery2 = 0.0;                    //voltage from pin A0
float voltage_reference2 = 0.0;                  //reference voltage on the arduino 5V-rail
float voltage_divider = (6780.0+2720.0)/2720.0;  //((R1+R2)/R2)*voltage for voltage divider before pin A0
 pinMode(screen_backlight, OUTPUT);       //LCD Setup
 digitalWrite(screen_backlight, HIGH);    // turn backlight on. Replace 'HIGH' with 'LOW' to turn it off.
 lcd.begin(20,4);                         // columns, rows.  use 16,2 for a 16x2 LCD, etc.
 lcd.clear();                             // start with a blank screen
//method 1
int getBandgap(void) // Returns actual value of Vcc  (x100)
     #if defined(__AVR_ATmega1280__) || defined(__AVR_ATmega2560__)
       // For mega boards
       const long InternalReferenceVoltage = 1115L;  // Adjust this value to your boards specific internal BG voltage x1000
       // REFS1 REFS0          --> 0 1, AVcc internal ref. -Selects AVcc reference
       // MUX4 MUX3 MUX2 MUX1 MUX0  --> 11110 1.1V (VBG)         -Selects channel 30, bandgap voltage, to measure
       ADMUX = (0<<REFS1) | (1<<REFS0) | (0<<ADLAR)| (0<<MUX5) | (1<<MUX4) | (1<<MUX3) | (1<<MUX2) | (1<<MUX1) | (0<<MUX0);
     #else
       // For 168/328 boards
       const long InternalReferenceVoltage = 1056L;  // Adjust this value to your boards specific internal BG voltage x1000
       // REFS1 REFS0          --> 0 1, AVcc internal ref. -Selects AVcc external reference
       // MUX3 MUX2 MUX1 MUX0  --> 1110 1.1V (VBG)         -Selects channel 14, bandgap voltage, to measure
       ADMUX = (0<<REFS1) | (1<<REFS0) | (0<<ADLAR) | (1<<MUX3) | (1<<MUX2) | (1<<MUX1) | (0<<MUX0);
     #endif
     delay(50);  // Let mux settle a little to get a more stable A/D conversion
     // Start a conversion
     ADCSRA |= _BV( ADSC );
     // Wait for it to complete
     while( ( (ADCSRA & (1<<ADSC)) != 0 ) );
       // Scale the value
       int results = (((InternalReferenceVoltage * 1024L) / ADC) + 5L) / 10L; // calculates for straight line value
       return results;
//method 2
long readVcc() {
 // Read 1.1V reference against AVcc
 // set the reference to Vcc and the measurement to the internal 1.1V reference
 #if defined(__AVR_ATmega32U4__) || defined(__AVR_ATmega1280__) || defined(__AVR_ATmega2560__)
   ADMUX = _BV(REFS0) | _BV(MUX4) | _BV(MUX3) | _BV(MUX2) | _BV(MUX1);
 #elif defined (__AVR_ATtiny24__) || defined(__AVR_ATtiny44__) || defined(__AVR_ATtiny84__)
   ADMUX = _BV(MUX5) | _BV(MUX0);
 #elif defined (__AVR_ATtiny25__) || defined(__AVR_ATtiny45__) || defined(__AVR_ATtiny85__)
   ADMUX = _BV(MUX3) | _BV(MUX2);
 #else
   ADMUX = _BV(REFS0) | _BV(MUX3) | _BV(MUX2) | _BV(MUX1);
 #endif
 delay(2); // Wait for Vref to settle
 ADCSRA |= _BV(ADSC); // Start conversion
 while (bit_is_set(ADCSRA,ADSC)); // measuring
 uint8_t low  = ADCL; // must read ADCL first - it then locks ADCH
 uint8_t high = ADCH; // unlocks both
 long result = (high<<8) | low;
 result = 1.1 * (5.00/5.13) * 1023 * 1000 / result; // Calculate Vcc (in mV); 1125300 = 1.1*1023*1000
 //result = 1125300L / result; // Calculate Vcc (in mV); 1125300 = 1.1*1023*1000
 return result; // Vcc in millivolts
void read_voltage() {
 //method 1 using internal reference voltage
 voltage_reference1=(float)getBandgap();
 voltage_battery1=map(analogRead(0),0,1023.0,0.0,voltage_reference1) * voltage_divider;
 //method 2
 voltage_reference2 = readVcc();
 voltage_battery2 = map(analogRead(0),0,1023.0,0.0,voltage_reference2) * voltage_divider;
void screen_print() {
 //printing method 1
 lcd.setCursor(0,0);
 lcd.print(voltage_reference1 / 100);
 lcd.setCursor(0,1);
 lcd.print(voltage_battery1 / 100);
 //printing method 2
 lcd.setCursor(10,0);
 lcd.print(voltage_reference2 / 1000);
 lcd.setCursor(10,1);
 lcd.print(voltage_battery2 / 1000);
 //printing original method not bothering with voltage reference
 lcd.setCursor(0,3);
 lcd.print(analogRead(0)*voltage_divider/1023*5);
 read_voltage();
 screen_print();
Also, another issue is that some of the values seem to fluctuate on my LCD screen. This is especially apparent for method 2. Any suggestions on how to reduce this and make the value more stable? I've added a 470n capacitor between A0 and ground.
dhenry
Use smoothing:
Code: [Select]
volt_avg = alpha * read_volt() + (1-alpha) * volt_avg;
If you pick alpha to be 1/2^n, you can greatly simplify the math above.
Boopidoo
#39
Jan 04, 2013, 02:55 pm Last Edit: Jan 04, 2013, 03:00 pm by Boopidoo Reason: 1
How do you mean? Sorry if I'm a little slow. :)
I tried testing in just below 0°C and now I just bothered to take notes on method 2 and 3 since 1 was too far off.
Powering using USB:
4.47V (measured using my meter)
4.45V (method 2) diff 0.4%
4.39V (method 3) diff 1.8%
Powering usning 3S:
11.55V (measured using my meter)
11.56V (method 2) diff 0.1%
11.54V (method 3) diff 0.1%
Now if it gets even colder I will try again but for now I pretty happy with method 2, it seems to be very consistent with my meter which was what I strived for in the start.
Boopidoo
When should I use a capacitor like this? On all analog inputs? I have some inputs that goes straight from a 0-5V source and thus doesn't need a voltage divider but do I still need the capacitor?
Also should I route both ground and + from this source? I also monitor its voltage so I guess there's a risk of ground loops.
Docedison
Quote
Quote from: dhenry on January 02, 2013, 03:55:02 PM
What I fail utterly to see here is how a component that can be anywhere in a 10,000 to 1 range could possibly be meaningful compensation for anything.
Bob
--> WA7EMS <--
"The solution of every problem is another problem." -Johann Wolfgang von Goethe
I do answer technical questions PM'd to me with whatever is in my clipboard
retrolefty
Quote
Bob
The concept of adding a cap is if the output impedance of whatever is driving the analog input pin is higher then 10K ohms then the internal sample and hold cap may not have time to charge up to the true value of the applied voltage. Possible solutions are:
Buffer the applied voltage with a device that meets the output impedance recommendation of the AVR ADC
Do consecutive analogRead() commands on the same input pin and ignore the first reading obtained
Add a small cap that will accumulate the charge of the applied voltage and will be able to transfer that charge voltage faster to the internal sample and hold cap when the pin is read.
Lefty
Boopidoo
Is there a risk when adding a cap when it's not really neccessary?
retrolefty
Nothing damaging, but if high speed sampling is being done on higher frequency type analog signals the cap may act as a low pass filter not giving as accurate a sample as it would without it.
Lefty
