Topic: Help with shrinking program on to Tiny85 (Read 5658 times) previous topic - next topic
kculm
Hi all,
I need a little help.
I have written a simple little sketch involving 3 LED's and A Push Button.
It works fine on the Bread Board hooked up to the Arduino UNO. But when I put the code on a atTiny85 it wont run.  I know I am programming the chip right. I have tested it with the Blink sketch.
I think it has something to do with the way I have it set up. I noticed pin 2 on the Arduino when sent as Analog input give out about 2 vdc,    Pin 2(3) on the Tiny85 puts out 5.  Not sure if I am on the right track with that.  all so please keep in mind I am very new to all this, just over a week old.
Attached is my code.
Thanks
Code: [Select]
*  Night Lite, final version
int switchPin = 3;              // switch is connected to pin 3 (pin 2 on Arduino)
int led1Pin = 0;                // Blue LED on Pin 8 on Arduino
int led2Pin = 1;                // Green LED on Pin 9 on Arduino
int led3Pin = 2;               // Red LED on Pin 10  on Arduino
int val;                        // variable for reading the pin status
int val2;                       // variable for reading the delayed status
int buttonState;                // variable to hold the button state
int lightMode = 0;              // What mode is the light in?
 pinMode(switchPin, INPUT);    // Set the switch pin as input
 pinMode(led1Pin, OUTPUT);
 pinMode(led2Pin, OUTPUT);
 pinMode(led3Pin, OUTPUT);
 Serial.begin(9600);           // Set up serial communication at 9600bps
 buttonState = digitalRead(switchPin);   // read the initial state
void loop(){
 val = digitalRead(switchPin);      // read input value and store it in val
 delay(10);                         // 10 milliseconds is a good amount of time
 val2 = digitalRead(switchPin);     // read the input again to check for bounces
 if (val == val2) {                 // make sure we got 2 consistant readings!
   if (val != buttonState) {          // the button state has changed!
     if (val == LOW) {                // check if the button is pressed
       if (lightMode == 0) {          // if its off
         lightMode = 1;               // turn lights on!
       else {
         if (lightMode == 1) {        // if its all-on
           lightMode = 2;             // make it blink!
         else {
           if (lightMode == 2) {      // if its blinking
             lightMode = 3;           // make it wave!
           else {
             if (lightMode == 3) { //  if its waving,
               lightMode = 4;
             else{
               if (lightMode == 4){
                 lightMode =0;
               } // turn light off!
     buttonState = val;                 // save the new state in our variable
   // Now do whatever the lightMode indicates
   if (lightMode == 0) { // all-off
     digitalWrite(led1Pin, LOW);
     digitalWrite(led2Pin, LOW);
     digitalWrite(led3Pin, LOW);
   if (lightMode == 1) { // Blue On
     digitalWrite(led1Pin, HIGH);
   if (lightMode == 2) { // Blue off, Green On
     digitalWrite(led2Pin, HIGH);
   if (lightMode == 3)  { // Red On Green Off
     digitalWrite(led3Pin, HIGH);
   if (lightMode == 4) { // Flame
     analogWrite(led1Pin, random(120)+135);
     analogWrite(led2Pin, random(120)+135);
     analogWrite(led3Pin, random(120)+135);
     delay(random(100));
strykeroz
Just to check your connections,
int switchPin = 3;              // leg 3 on the ATTiny85
int led1Pin = 0;                // leg 5
int led2Pin = 1;                // leg 6
int led3Pin = 2;               // leg 7 but it's NOT PWM capable, so your analogWrites won't work; suggest you move this one to leg 2 or 3 (D3 or D4 if you still need to analogWrite)
Cheers ! Geoff
Cheers ! Geoff
"There is no problem so bad you can't make it worse" - retired astronaut Chris Hadfield
kculm
The image I have shows pin 3 on leg two.
Leg 1 Reset
Leg 2 PIN 3( Analog input 3)
Leg 3 PIN 4( Analog input 2)
Leg 4 GND
Leg 5 PIN 0 (PWM)
Leg 6 PIN 3 (PWM)
Leg 7 PIN 2 (Analog Input 1)
Leg 8 VCC
strykeroz
Sorry that was a typo. You are correct.
kculm
Thanks,
did you take a look at my lay out ?
strykeroz
Just now, yes.
So the PWM remark still stands. Suggest using the internal pull-up on your switch pin to simplify, and swap switch and LED pins so you get PWM for analog write on that 3rd LED.
In around an hour if you like I'll be able to load this up on an ATTiny85 if you don't find what's breaking it first.
Cheers! Geoff
strykeroz
You need to lose this too...
Code: [Select]
Cheers! Geoff
kculm
That would be great if you could do that,
Cheers! Geoff
kculm
Not sure how to do this. To tell you the truth I am not even sure what it means  :smiley-red:
Cheers! Geoff
strykeroz
No need to do that to fix anything, but a suggestion.  Simply setMode to output as you would, but then digitalWrite that pin to high.  Wire the pin to yor switch then ground.  When not pressed the pin will digitalread high, and when pressed it will be low.  But it means your switch circuit will be much simplified.
Regardless it is working the way you have it so I think just move LED3 to a pin that supports PWM, and lose the initiation of Serial...and i think it should run as it did for you on the arduino.
Geoff
kculm
There are only 2 PWM pins  PIN 0 (5)
and PIN 1 (6)
kculm
I removed this line, and reprogrammed the 85 and it working some what.
But if your still willing to take a shot at I would deeply appreciate it.
Code: [Select]
Cheers! Geoff
strykeroz
#12
Jan 02, 2013, 06:09 am Last Edit: Jan 02, 2013, 06:10 am by strykeroz Reason: 1
and PIN 1 (6)
This is a common misconception.  ATTiny85 has 4 pins capable of PWM, with two sharing the same clock source.  I routinely use this little uC to run RGB LEDs.
Sorry still stuck on this iPad or would post an example.
Also, it is possible to drive any of the pins by software PWM if the application is lighting or anything else where accuracy or high frequencies aren't a requirement.
Cheers! Geoff
kculm
I am  sorry if I am being a pain, but can you list the 4 PWM pins.
I am still learning and you are helping me a lot. I have a long way to tho...
Thanks
strykeroz
Not a problem at all.  Sorry I type better on my PC too :)
Checkout the pins on this diagram http://www.akafugu.jp/images/microcontroller-reference-sheet.png
It is only those two PWM pins on ATTiny13.
Cheers! Geoff
