Loading...
Pages: [1]   Go Down
Author Topic: SoftwareSerial - Bug  (Read 1712 times)
NSW, Australia
Offline Offline
Newbie
View Profile
WWW
Hello,
We are having problems with the SoftwareSerial library found in the Arduino 1.02 Release.
When the SoftwareSerial is initialised, it sets the tx port to output and then sets it to HIGH. This causes a momentary low spike that is being interpreted as a start bit on some controllers.
The code currently is:-
Code:
void SoftwareSerial::setTX(uint8_t tx)
  pinMode(tx, OUTPUT);
  digitalWrite(tx, HIGH);
  _transmitBitMask = digitalPinToBitMask(tx);
  uint8_t port = digitalPinToPort(tx);
  _transmitPortRegister = portOutputRegister(port);
The 'fixed' code is:-
Code:
This solves the issue.
Please advise
Regards
4D Systems
Logged
Left Coast, CA (USA)
Offline Offline
Brattain Member
Measurement changes behavior
View Profile
Interesting. What the fix is doing is enabling the internal pull-up resistor on the pin number in question while it's still an input pin so that when the pin mode is changed to output mode it's already at a high state, otherwise without out that, when the pin mode is first changed to output mode it's default state is low until the very next digitalWrite (tx,HIGH) is executed, causing the downstream circuit to see a very brief low 'spike' before the high takes place.
Lefty
Another maybe ( or maybe not) clearer 'fix' that does the same thing might be to use:
Code:
  pinMode(tx, INPUT_PULLUP);
« Last Edit: January 01, 2013, 11:51:46 pm by retrolefty » Logged
Global Moderator
Dallas
Online Online
Shannon Member
View Profile
WWW
@4D_Systems, please create an issue here...
https://github.com/arduino/Arduino/issues
https://github.com/arduino/Arduino/issues/new
Logged
NSW, Australia
Offline Offline
Newbie
View Profile
WWW
Done
https://github.com/arduino/Arduino/issues/1195
Thank you
Logged
NSW, Australia
Offline Offline
Newbie
View Profile
WWW
Hello again
After posting the bug report 8 days ago, still no one seems to be assigned to the bug...
Is there anything further we can do to get this seen to?
Looking at other bug reports, there seem to be numerous without someone being assigned to them either...
Can probably put a lot of it down to the holiday season.
Please advise
Regards
4D Systems
Logged
Seattle, WA USA
Offline Offline
Brattain Member
Seattle, WA USA
View Profile
Quote
And other priorities, and a small staff. Patience, grasshopper.
Logged
Global Moderator
Dallas
Online Online
Shannon Member
View Profile
WWW
Hello,
Absolutely!  Fork.  Fix.  Submit a pull request.
This dramatically increases the chances of the change being included much sooner than if you rely on someone else.
As an added bonus, until the fix has been applied, you can maintain your own up-to-date version by re-merging and using your fork.
Logged
Pages: [1]   Go Up
Print
Jump to:
