Author Topic: Digital to Analogue  (Read 341 times)
Is that not PWM?
California
Online Online
Context?
The most use Arduino Uno board doesn't have an DAC onboard. But it can output a PWM signal.
So the function analogWrite() is actually outputting a PWM signal to a digital output pin.
http://arduino.cc/en/Reference/analogWrite
This is good for leds and motors.
The new Arduino Due with ARM processor does have DAC outputs : http://arduino.cc/en/Main/ArduinoBoardDue
Nope.  PWM is digital; with PWM and a capacitor to integrate the pulses you can 'fake' an analog output, but that's slow.
analogWrite(255/2) on PWM will give you an on-off signal with 50% duty cycle; half the time it'll be on at full voltage (3.3v on the Due), half it'll be off.  As mentioned above, with a capacitor and a resistor you can integrate these pulses into a voltage, but it's slow and a pain in the butt and requires more components.
analogWrite(255/2) on a Due's DAC should give you a steady voltage of about half of 3.3v.
Of course, this assumes the resolution on both is 8 bits.
In some cases either can be fine, but when you need a real DAC, like for audio output, you need a real DAC
Manchester (England England)
Solder is electric glue
See this for what PWM actually is:-
http://www.thebox.myzen.co.uk/Tutorial/PWM.html
 i know what pulse width modulation is all about...
creating a low bit rate audio signal and output it via an atmega...  what would that be called ifnot a DAC?
UK
I'm not sure what you're trying to say here, but "creating a low bit rate audio signal and output it via an atmega" does not mean the same thing as PWM or DAC.
Dubai, UAE
The difference between DAC and PWM is that PWM is not going to get you high resolutions at high frequency.
For example if you wanted to output 16bit audio on an Arduino UNO running at 16Mhz, in theory you could use the 16 bit timer1.
In practice your output quality would be terrible because the UNO can only count to 65535  244 times a second where as you would want to run your audio interrupts at typical rates of 8,000 or 16,000 samples per second.
A DAC does not have this counting limitation.
Duane B
rcarduino.blogspot.com
Then you should know that it is not a D/A.
It is a time to analogue converter. Not a digital to analogue converter.
