Topic: High Voltage (Read 2035 times) previous topic - next topic
hanyc93
Do anyone know how to use arduino to turn on a 120 V fan?
Thanks!
cjdelphi
I'd use a relay.. any old relay, or buy a breakout board with a relay on (comes with optoisolaters/diodes)
Grumpy_Mike
Or use a solid state relay, they are called SSR
hanyc93
rvasque
If it's a DC motor, you can use an SCR (Silicon Controlled Rectifier).
If it's an AC motor, you can use a TRIAC.
You can also use mechanical relays, or solid state relays, or Mosfets.
Since it's line voltage, might also help to have some physical isolation between your low voltage electronics and the high voltage section (for added safety). You can use "optical" equipped mosfets, etc...  basically, your low voltage electronics turns on a small LED (inside the mosfet), and the light emitted is detected, which then switches/turns on the high voltage side of the Mosfet (everything happening internally).
JimboZA
Adafruit has this.
Disclaimer... it says something about derating when the load isn't resistive and I think a motor is inductive?
Johannesburg hams call me: ZS6JMB on Highveld rep 145.7875 (-600 & 88.5 tone)
Dr Perry Cox: "Help me to help you, help me to help you...."
Your answer may already be here: https://forum.arduino.cc/index.php?topic=384198.0
rvasque
Thanks for the link. That is pretty good pre-packaged solution.
For motors, use 20% of rated... so 15A x .2 = 3Amp max.
retrolefty
Quote
That is not true, a SCR will not control a DC motor as once you trigger the SCR on the only way to turn it off is to remove power from the motor circuit.
Lefty
rvasque
Quote
Lefty
You're right about the SCR. I was just thinking of turning it ON.
Docedison
No... Not Quite... @Lefty What about commutation with an inductive load?  <BFG>
Bob
--> WA7EMS <--
"The solution of every problem is another problem." -Johann Wolfgang von Goethe
I do answer technical questions PM'd to me with whatever is in my clipboard
