Topic: SIM900 Call example (Read 555 times) previous topic - next topic
Marciokoko
Hello,
Im using what appears to be known as a SIM900 breakout, since it doesn't have an accompanying set of pinouts that plug into the Arduino MEGA in my case.
Anyway, Im guessing the 5V & GND go to their respective counterparts in the MEGA.  The TXD should go to the RXD in the MEGA and vv.
Im wondering why I have a second GND pin on my SIM900 breakout?
But more importantly, Im trying to run a simple example sketch that came with the library example I got from:
https://github.com/MarcoMartines/GSM-GPRS-GPS-Shield
but Im getting this error just upon compiling:
Code: [Select]
GSMSHIELD/SIM900.cpp:875:9: error: 'class HWSerial' has no member named 'print'
   _cell.print(F("\r"));
Error compiling.
Here is the sketch example:
Code: [Select]
#include "SIM900.h"
#include <SoftwareSerial.h>
//We don't need the http functions. So we can disable the next line.
//#include "inetGSM.h"
#include "sms.h"
#include "call.h"
//To change pins for Software Serial, use the two lines in GSM.cpp.
//GSM Shield for Arduino
//www.open-electronics.org
//this code is based on the example of Arduino Labs.
//Simple sketch to check if an incoming call is from an authorized
//number and in this case, send to this number an SMS with the value
//of a digital input.
//We have to create the classes for SMSs and calls.
CallGSM call;
SMSGSM sms;
char number[20];
byte stat=0;
int value=0;
int pin=1;
char value_str[5];
  pinMode(pin,INPUT);
  //Serial connection.
  Serial.println("GSM Shield testing.");
  //Start configuration of shield with baudrate.
  //For http uses is raccomanded to use 4800 or slower.
  if (gsm.begin(2400))
    Serial.println("\nstatus=READY");
  else Serial.println("\nstatus=IDLE");
  //Chekcs status of call
  stat=call.CallStatusWithAuth(number,1,3);
  //If the incoming call is from an authorized number
  //saved on SIM in the positions range from 1 to 3.
  if(stat==CALL_INCOM_VOICE_AUTH){
    //Hang up the call.
    call.HangUp();
    delay(2000);
    //Check the value of the input.
    value=digitalRead(1);
    //Convert the int to a string.
    itoa(value,value_str,10);
    //Send an SMS to the previous number with
    //the value read previously.
    sms.SendSMS(number,value_str);
Thanks
