Topic: A noob resistance question (Read 11890 times) previous topic - next topic
anorton
40ma is absolute maximum, but 20-30 ma is a better maximum limit standard to stick to. Keep in mind due to internal resistance of the output pins the output voltage will sag as current draw from the output pin is increased. Just shows that there is a difference from fundamental principal and electrical reality of real world components. That is why the datasheet for devices are so important to study and understand a chip limits and capabilities.
Ok.
Quote
Because there is no exact answer. If the board is being powered via USB then there is a 500ma thermofuse that sets a maximum limit for the board and anything you wire up to it. But if powered from an external DC voltage source then there might be somewhat more but it depends on the exact DC voltage input as there is a heat dissipation limit for the on-board 5vdc voltage regulator. So hard answers are desirable but often allusive in the real world.
Hmmm... Ok.  Where do I find the information for the on-board 5vdc regulator?
Quote
No, totally different components, and a switch doesn't share all the characteristic of a switch and visa versa.
:-\  Just when I thought I found a shortcut... ;)  Ok.
oric_dan
Quote
When performing Ohm's Law calculations, what specifies the values for V and I?
V, to me, should be the supply voltage (3.3V or 5V would be what I'm using in this case).
No, V is actually the voltage "drop" across the resistor. Eg, if 1K is tied between 5V and
3.3V, the current I = Vdrop / R = (5V - 3.3V) / 1K = 1.7 mA, and not 5 mA or 3.3 mA.
anorton
Quote
In your example, you mean a 1K(ohm) resistor, right?  (just making sure--I'm really new, if you haven't figured it out yet.  :smiley-red:)
So, in this LED (for example), it says "forward voltage drop" is 1.8V-2.2V (DC).  Let's say I have a circuit that has 5V---LED---1K(ohm)---Gnd.  I want to find the current.  I = Vdrop / R = 2.2V / 1K = 2.2mA.
Right?  Or am I still confused... :/
Grumpy_Mike
No with a forward voltage drop on the LED of 2.2V the drop across the resistor is 5 - 2.2 = 2.7 V
You can not use ohms law for an LED it does not work because it is a non linear device. Only the resistor.
JimboZA
Quote
32Mhz (forgive the capitalized M if it is incorrect please)
The M's right, but the h's not.... Hertz's symbol is Hz, so you should write MHz
Johannesburg hams call me: ZS6JMB on Highveld rep 145.7875 (-600 & 88.5 tone)
Dr Perry Cox: "Help me to help you, help me to help you...."
Your answer may already be here: https://forum.arduino.cc/index.php?topic=384198.0
JimboZA
#20
Jan 03, 2013, 06:35 am Last Edit: Jan 03, 2013, 07:19 am by JimboZA Reason: 1
My tuppence worth....
I think what might not be becoming clear to messrs anorton and macweenie yet, is the notion that all of the voltage across the LED and its resistor has to be accounted for: the 5v in the 5V---LED---1K(ohm)---Gnd scenario has to disappear by the time we get to the right hand end.
So here's how it all hangs together....
1) What's the input voltage? We're saying 5v, so we have that.
2) What's the voltage we must account for over the LED? Manufacturer will tell us, let's go with the 2.2V mentioned earlier
3) So what voltage must we disappear over the resistor? We started with 5, accounted for 2.2, so we have 2.8 left to drop over the resistor
4) How are we doing with Ohm's Law for the resistor so far? Well we don't know R, that's what we need to calculate; we do know the voltage (2.8v); we don't know the current....
5) But we do know that in a series circuit like this, the current through the LED has to go through the resistor: there's no other path. And we do know (or manufacturer will tell us) that it's 20mA, or 0.020A... this is the value to which we need to limit the current, the object of the exercise.
6) So now we can apply Herr Ohm to the resistor with R=V/I giving R=2.8/0.02 = 140 Ohm
EDIT:
This is all a consequence of Kirchoff's Voltage Law which Wikipedia describes thusly:
Quote
The algebraic sum of the products of the resistances of the conductors and the currents in them in a closed loop is equal to the total emf available in that loop.
The products of the resistances of the conductors and the currents is simply the voltages (Ohm's Law).
Do we have a loop though? The 5V---LED---1K(ohm)---Gnd doesn't look like a loop... but it is if you think of the 5v and Gnd being eg the two terminals on a battery... then it would look like a loop: 5V---LED---1K(ohm)---Gnd---Battery---5v
So now we can see Kirchoff's Voltage Law at work in our simple circuit...
1) Total EMF available in loop: 5V
2) Sum of the voltages in the loop: Vled + Vresistor = 2.2 + Vresistor
3) So 5 = 2.2 + Vresistor or Vresistor = 5 - 2.2
Does that help?
oric_dan
Quote
In your example, you mean a 1K(ohm) resistor, right?  (just making sure--I'm really new, if you haven't figured it out yet.  )
Yeah, the other guys are correct, and as I said you use "the voltage "drop" across the resistor"
to get the current through it. Ohm's Law is for resistors.
anorton
JimboZA's post really cleared it up for me--I needed that background information that is probably really basic to a lot of people here... :)
Thanks, everyone, for all your help!
//Andrew
macweenie
Thanks JimboZA,
Although I got a great deal of information before your post, you gave me the piece of the puzzle I was lacking. I hadn't understood just WHERE the current I needed to power, in this case, an LED was coming from. Having looked briefly at the datasheets for different chips and sensors I wasn't making the now obvious connection that the items current requirements was in there. I was under the assumption that 15mA (right?) was the rule of thumb for ALL LEDs, but now it's so obvious I could face-palm.
So using the following datasheet:
I would subtract 4V (maximum forward voltage) from the 5V the Arduino is putting out to get a drop voltage of 1V which using V = r * I would be 1V = r * 20mA or 1 / .2 = a 5 ? resistor? I combed the datasheet for any other values that looked right but theses were the only ones that seemed to fit the bill.
retrolefty
Quote
No .2 is 200 ma, you need to use .02 in your calculation.
Lefty
macweenie
The moment I hit post I knew I screwed up, but the dog asked to go out and you caught it before I could fix it :smiley-red:.
so it should be a 50? resistor... Do you know HOW I know I want to learn this? Because I keep on trying even though I have been wrong 100% of the time!
retrolefty
Oh, the old "the dog eat my correct posting" excuse, go to the corner.  ;)
fungus
Are you sure?
No, I don't answer questions sent in private messages (but I do accept thank-you notes...)
fungus
Thanks JimboZA,
Glad you understand it.
Now you're getting good a reading datasheets, the second thing you need to look at is the graph of voltage vs. current and the min/max range of voltages that the LED needs. As you'll see the graph shows that ass you approach maximum current, even minor variations in voltage (eg. 0.1V) can produce <b>huge</b> difference differences in current. The LEDs voltage tolerances are often more than 0.1V either way, so what voltage do you aim at...?
This is why controlling LEDs with resistors is a bad idea, and why they make special chips for driving LEDs - you need to control the current, not the voltage.
Grumpy_Mike
Quote
It is not a bad idea it is done all the time in a lot of professional applications and is quite satisfactory technique. It is not the technique to get the absolute exact control over the current but often this is not necessary.
