Topic: A noob resistance question (Read 11826 times) previous topic - next topic
macweenie
Quote
The LEDs voltage tolerances are often more than 0.1V either way, so what voltage do you aim at...?
Well fungus, I would say that I would add the 0.1V to the 4V maximum forward voltage so 5V - 4.1V = 0.9V drop voltage, then to calculate the resistor needed (if I use a resistor vs a chip) it would be 0.9V / .02mA = a 45? resistor (or the next larger value), HOWEVER since I am always wrong about these things my gut is telling me to SUBTRACT 0.1V from the 4.0V BECAUSE it is the MAXIMUM forward voltage and if it is maximum then I can't go beyond it right? So 5V - 3.9V = 1.1V and 1.1V / .02mA = a 195? resistor (or the next larger value). I am aware that you may have been asking a rhetorical question, but I wasn't sure.
fungus
It was rehetorical. The correct answer is not to aim for a voltage.
No, I don't answer questions sent in private messages (but I do accept thank-you notes...)
fungus
Quote
This is why controlling LEDs with resistors is a bad idea,
It is not a bad idea it is done all the time in a lot of professional applications and is quite satisfactory technique. It is not the technique to get the absolute exact control over the current but often this is not necessary.
If you're aiming at 10-12mA (or less) on a 20mA LED, sure. The power curve is usually quite flat there.
If you're aiming at 20mA on a 20mA LED then resistors simply don't work.
macweenie
Since you brought it up, I was wondering, How does using an LED Driver IC differ from powering the LEDs through a PWM enabled pin? Couldn't I use a shift register IC on a PWM pin to get the same result? Not that I have any immediate plans.
Grumpy_Mike
Quote
Rather the same way as driving a car differs from making a cake. No relationship whatsoever.
fungus
It's completely different.
Not all ICs do PWM.
The IC will clamp the LED current to a fixed value (eg. 20mA), independent of voltage.
