Pages: 1 [2] 3   Go Down
Author Topic: A noob resistance question  (Read 887 times)
Left Coast, CA (USA)
Measurement changes behavior
I was about to start a thread on this very topic, but apparently it has been asked before! smiley
After reading through the thread (and the links posted therein), I have a couple of questions:
1. When performing Ohm's Law calculations, what specifies the values for V and I?
V, to me, should be the supply voltage (3.3V or 5V would be what I'm using in this case).  And should I be the maximum allowable current to pull from the pin?  Just wanting to make sure... smiley
40ma is absolute maximum, but 20-30 ma is a better maximum limit standard to stick to. Keep in mind due to internal resistance of the output pins the output voltage will sag as current draw from the output pin is increased. Just shows that there is a difference from fundamental principal and electrical reality of real world components. That is why the datasheet for devices are so important to study and understand a chip limits and capabilities.
2. What is the maximum allowable current draw for the 5V pin on an Arduino Uno?  From this page, I see 50mA for the 3.3V pin, but nothing is listed for the 5V pin.
Because there is no exact answer. If the board is being powered via USB then there is a 500ma thermofuse that sets a maximum limit for the board and anything you wire up to it. But if powered from an external DC voltage source then there might be somewhat more but it depends on the exact DC voltage input as there is a heat dissipation limit for the on-board 5vdc voltage regulator. So hard answers are desirable but often allusive in the real world.
3. Can one model a switch/pushbutton similarly to an LED?  I ask this because a switch also has "infinite" resistance when not activated, but near 0 resistance when pressed.
No, totally different components, and a switch doesn't share all the characteristic of a switch and visa versa.
Programming and Math enthusiast venturing into the hardware relm.
Ok.
Hmmm... Ok.  Where do I find the information for the on-board 5vdc regulator?
:-\  Just when I thought I found a shortcut... smiley-wink  Ok.
the land of sun+snow
No, V is actually the voltage "drop" across the resistor. Eg, if 1K is tied between 5V and
3.3V, the current I = Vdrop / R = (5V - 3.3V) / 1K = 1.7 mA, and not 5 mA or 3.3 mA.
Kitchen-Sink Arduino-compatible boards
In your example, you mean a 1K(ohm) resistor, right?  (just making sure--I'm really new, if you haven't figured it out yet.  smiley-red)
So, in this LED (for example), it says "forward voltage drop" is 1.8V-2.2V (DC).  Let's say I have a circuit that has 5V---LED---1K(ohm)---Gnd.  I want to find the current.  I = Vdrop / R = 2.2V / 1K = 2.2mA.
Right?  Or am I still confused... :/
Manchester (England England)
Online Online
Solder is electric glue
No with a forward voltage drop on the LED of 2.2V the drop across the resistor is 5 - 2.2 = 2.7 V
You can not use ohms law for an LED it does not work because it is a non linear device. Only the resistor.
Johannesburg UTC+2
32Mhz (forgive the capitalized M if it is incorrect please)
The M's right, but the h's not.... Hertz's symbol is Hz, so you should write MHz
IT Crowd:
Roy... "Have you tried turning it off and on again?"
Moss.. "Have you tried forcing an unexpected reboot?"
Johannesburg UTC+2
My tuppence worth....
I think what might not be becoming clear to messrs anorton and macweenie yet, is the notion that all of the voltage across the LED and its resistor has to be accounted for: the 5v in the 5V---LED---1K(ohm)---Gnd scenario has to disappear by the time we get to the right hand end.
So here's how it all hangs together....
1) What's the input voltage? We're saying 5v, so we have that.
2) What's the voltage we must account for over the LED? Manufacturer will tell us, let's go with the 2.2V mentioned earlier
3) So what voltage must we disappear over the resistor? We started with 5, accounted for 2.2, so we have 2.8 left to drop over the resistor
4) How are we doing with Ohm's Law for the resistor so far? Well we don't know R, that's what we need to calculate; we do know the voltage (2.8v); we don't know the current....
5) But we do know that in a series circuit like this, the current through the LED has to go through the resistor: there's no other path. And we do know (or manufacturer will tell us) that it's 20mA, or 0.020A... this is the value to which we need to limit the current, the object of the exercise.
6) So now we can apply Herr Ohm to the resistor with R=V/I giving R=2.8/0.02 = 140 Ohm
EDIT:
This is all a consequence of Kirchoff's Voltage Law which Wikipedia describes thusly:
The algebraic sum of the products of the resistances of the conductors and the currents in them in a closed loop is equal to the total emf available in that loop.
The products of the resistances of the conductors and the currents is simply the voltages (Ohm's Law).
Do we have a loop though? The 5V---LED---1K(ohm)---Gnd doesn't look like a loop... but it is if you think of the 5v and Gnd being eg the two terminals on a battery... then it would look like a loop: 5V---LED---1K(ohm)---Gnd---Battery---5v
So now we can see Kirchoff's Voltage Law at work in our simple circuit...
1) Total EMF available in loop: 5V
2) Sum of the voltages in the loop: Vled + Vresistor = 2.2 + Vresistor
3) So 5 = 2.2 + Vresistor or Vresistor = 5 - 2.2
Does that help?
« Last Edit: January 03, 2013, 01:19:28 am by JimboZA » Logged
IT Crowd:
In your example, you mean a 1K(ohm) resistor, right?  (just making sure--I'm really new, if you haven't figured it out yet.  )
Yeah, the other guys are correct, and as I said you use "the voltage "drop" across the resistor"
to get the current through it. Ohm's Law is for resistors.
JimboZA's post really cleared it up for me--I needed that background information that is probably really basic to a lot of people here... smiley
Thanks, everyone, for all your help!
//Andrew
US
Thanks JimboZA,
Although I got a great deal of information before your post, you gave me the piece of the puzzle I was lacking. I hadn't understood just WHERE the current I needed to power, in this case, an LED was coming from. Having looked briefly at the datasheets for different chips and sensors I wasn't making the now obvious connection that the items current requirements was in there. I was under the assumption that 15mA (right?) was the rule of thumb for ALL LEDs, but now it's so obvious I could face-palm.
So using the following datasheet:
I would subtract 4V (maximum forward voltage) from the 5V the Arduino is putting out to get a drop voltage of 1V which using V = r * I would be 1V = r * 20mA or 1 / .2 = a 5 Ω resistor? I combed the datasheet for any other values that looked right but theses were the only ones that seemed to fit the bill.
No .2 is 200 ma, you need to use .02 in your calculation.
Lefty
US
The moment I hit post I knew I screwed up, but the dog asked to go out and you caught it before I could fix it smiley-red.
so it should be a 50Ω resistor... Do you know HOW I know I want to learn this? Because I keep on trying even though I have been wrong 100% of the time!
Oh, the old "the dog eat my correct posting" excuse, go to the corner.  smiley-wink
Valencia, Spain
Are you sure?
Valencia, Spain
Thanks JimboZA,
Glad you understand it.
Now you're getting good a reading datasheets, the second thing you need to look at is the graph of voltage vs. current and the min/max range of voltages that the LED needs. As you'll see the graph shows that ass you approach maximum current, even minor variations in voltage (eg. 0.1V) can produce <b>huge</b> difference differences in current. The LEDs voltage tolerances are often more than 0.1V either way, so what voltage do you aim at...?
This is why controlling LEDs with resistors is a bad idea, and why they make special chips for driving LEDs - you need to control the current, not the voltage.
Pages: 1 [2] 3   Go Up
