Topic: Newbie question on designing your own 'board' instead of using wires (Read 14297 times) previous topic - next topic
rvasque
I've been playing with DipTrace on and off... so far, I'm liking it's features. Haven't gotten to defining my own part yet.
It seems very powerful and lots of editing options...
It's fugly though on an OSX, and hate seeing the C:\Program Files\blah blah blah directory structure.
JoeN
I used to do PowerBuilder on Macs and it was the same way, essentially they were just emulating most of it so it had the same structure as the PC version.
I had to do a couple of matricies in the component / pattern editor.  It's pretty easy and explained well in the tutorial.   This is an Adafruit 0.8" matrix with a pattern on a schematic.  Board should be coming tomorrow, hopefully I got everything right.  I'm already worried I made the power traces way too thin.  The MAX7219s and matricies are bussed out to 6 total pairs.
Component
Pattern
Schematic
PCB
I will never ask you to do anything that I wouldn't do myself.
Stijn
So in the mean time I dumped expresssch because I got the impression that I would get stuck and should go a bit more advanced so I started using Eagle.
I redid the scheme here:
There is a button board I noticed, can I just use this (items won't be in a nice order) or is it better to restart to create a board? Can wires cross, I guess not?
Thanks!
rvasque
You need to put junctions in your wire/schematic. I don't see any dots anywhere.
Good for you. Yeah, you want something that can output gerber so you can send the job to whomever you wish, and you're not tied up/hostaged by Express PCB.
Stijn
Thanks for that, I updated it with juctions. That was a great tip!
rvasque
You don't need junctions at the IC pins, or component, or input/output terminals. They're understood as already being connected.
But when you have 2 net wires crossing, and they're supposed to be connected, yes, put a junction there.
CrossRoads
Run the Schematic ERC (Tools:ERC) to make sure all the pins are connected. Or, wiggle each part a little to make sure wires are connected.
Can also use File:Export:Netlist to make sure all pins in a net are connected.
Really helps to name each signal (right click a signal, and use Name) when routing a board.  N$7 is not helpful as a Name!
Also, Edit:Net Classes to define trace widths, clearance around the trace, and via size to use.
You can select the Net Class for a trace in Properties as well.
db2db
Are these "wires" and not "nets"?  Seems like it since they didn't connect automatically.
You'll want to change that.
CrossRoads
On the schematic, you draw wires to connect things and give them a Net name.
On the board, you connect the traces. You can also add wires; they can be given Names also so they will connect to a Net.
Same with Vias (especially Gnd) and Polygons (for Gnd layers).
db2db
In Eagle you want to use nets, not wires.
CrossRoads
On the schematic, they are called Wire.
Draw: Wire.
Right click on a line, select Properties, and it opens a message box with Wire on the top, and Net on the bottom.
db2db
I hate to disagree with you, but here's a quote from Jorge at Cadsoft (Eagle) .
"Wires should only be used for artistic purposes, the name LINE would be
more inline with it's function than WIRE but for historical reasons it's
still named WIRE.
Never use WIRE to define connections in the schematic and in most cases
you don't want to use WIRE to define connections on the board.
Jorge Garcia"
more info here:
http://www.element14.com/community/message/38435#38435/l/aw-im-confused-about-adding-nets
rvasque
Well, that's freaking news to me. I've always used WIRE when drawing schematics all these years, never had any problem making PCBs from it... and I have thousands of boards/products out there in the field.
This is the icon I click in Eagle.
EDIT:
Okay, using the NET command saves me the step of placing a net junction as a separate task.
Other than that difference, if you look at properties, it's the same as using LINE then placing the junctions manually.
Stijn
So is using the button create PCB the correct next step or should I start from scratch?
I used this button to test and this surprised me: looking at my schematic you can see this:
But when I used the PCB button you can see that only these wires are not connected (on the left side, PUSHBUTTONSREAD):
The resistors are also missing here.
Thanks
db2db
Move that resistor back in the schematic and you'll see it's not actually connected. The wires won't move with it.
Again, NET is better.
