Loading...
Pages: [1]   Go Down
Author Topic: The Sarduinostat : an automated & web based heater controller / thermostat  (Read 585 times)
Offline Offline
Newbie
View Profile
Inspired by some nice (and well documented) projects found on the forum, I finally managed to release my first version of the Sarduinostat
(as you may have guessed, the project fits in a sardine / pilchard box)
Apart from being fully functionnal, the goal was to make it small enough to fit it in a sardine box (nicely painted by the way as it will be put on the wall)
I used mainly semi built parts (i.e. including required caps & resitors) to keep the project simple (no soldering required)
As it is my first real arduino project (and I am new to C), I suspect part of the code can be optimized / cleaned ...
Parts :
- a sardine box
- Arduino nano clone
- DS18B20 temperature sensor
- TM1638 based 8X Seven Segments Display
- ENC28J60 based ethernet card
- a server for some of the enhanced functionnalities (i.e. collectd monitoring, access to http services)
(less than 35€ if I did not make any mistake in calculations, all ordered from dx)
What it can already do
- activate / deactivate the heater through a relay
- multi-mode control : day, night, auto (program per 10 min step), off, force (force heating)
- general status on a visible 8 x 7 segments display or simple web page
- clear heating status through leds
- manageable through panel buttons or through http services
- dhcp / ntp enabled
- interface to collectd / RRD for constant temperature monitoring
What it may do in the future
- more (and cleaned) http services
- allow to change program through a web page
- manage a different program for each day of the week
- more functions through the included web page (I need to free some memory)
It will also look nicer than on the pictures once painted and the cable fitted inside. smiley-cool
Thanks to all people on the forum I've stolen code from smiley
Collectd snippet
Code:
LoadPlugin curl
<Plugin curl>
        <Page "thermostat">
        URL "http://thermos/status"
        <Match>
                Regex "Temperature : ([0-9]+)"
                DSType "GaugeLast"
                Type "temperature"
                Instance "Thermostat"
        </Match>
        <Match>
                Regex "Ref : ([0-9]+)"
                DSType "GaugeLast"
                Type "temperature"
                Instance "Reference"
        </Match>
        </Page>
</Plugin>
Server page snippet (jquery based page)
Code:
$('.thermos_button').click(function() {
      $.ajax({type:'GET',
              url:'http://thermos/'+this.id,
              success: function (resp) { alert(resp); }
Code:
<iframe src="http://thermos" id="thermos_status" width=400 height=230 frameborder=0>Thermos status</iframe><br>
    Change mode to :
    <button id="?mode=DAY" class="thermos_button">Day</button>
    <button id="?mode=NIGHT" class="thermos_button">Night</button>
    <button id="?mode=AUTO" class="thermos_button">Auto</button>
    <button id="?mode=OFF" class="thermos_button">Off</button>
    <button id="?mode=FORCE" class="thermos_button">Force</button><br/>
    Day temp :
    <button id="?dtemp+" class="thermos_button">+</button>
    <button id="?dtemp-" class="thermos_button">-</button><br/>
    Night temp :
    <button id="?ntemp+" class="thermos_button">+</button>
    <button id="?ntemp-" class="thermos_button">-</button><br/>
Logged
Pages: [1]   Go Up
Print
Jump to:
