Topic: How to add customized compiling message under Arduino IDE (Read 2525 times) previous topic - next topic
SteveChang
Hi All,
I want to add some customized output information in Arduino IDE when compiling the code written by me.
I tried #pragma message("hello"). It dispalyed nothing.
Can anybody know it?
Thanks,
Steve
Coding Badly
Coding Badly
#2
Jan 03, 2013, 05:06 am Last Edit: Jan 03, 2013, 06:15 am by Coding Badly Reason: 1
Another possibility (requires the condition to reduce to a compile-time constant)...
static void OutputsErrorIfCalled( void ) __attribute__ (( error("Unexpected condition encountered.") ));
void loop( void )
 if ( true )
   OutputsErrorIfCalled();
SteveChang
JediJeremy
Please don't.
I'm current looking for ways to disable the entire #pragma message system because devs are polluting it with "Hey, I'm so great!" messages that look like compilers errors to newbs.
Yes, we know we're using your library. We had to download and install it. Reminding us makes us look for a quieter one.
Coding Badly
OldSteve
Please don't.
Compiler messages are very useful.
For instance, you can write your code to work on a particular board or boards, then have an error generated (and compilation aborted) if you accidentally try to compile it for a different board.
e.g.
#ifndef __AVR_ATmega2560__  // Mega2560
#error Wrong chip defined - cannot continue! Please use an ATMega2560
#endif
I don't see any reference to the possibility that this might be code for public use in a distributed library, so no need to panic. It's probably for his own use.
Please do not PM me for help. I am not a personal consultant.
And others will benefit as well if you post your question publicly on the forums.
