Topic: Serial Event Monitor for Alarm System with SoftwareSerial (Read 2342 times) previous topic - next topic
aquadat0r
Hi there,
I'm looking at making use of the SoftwareSerial library to primarily monitor the serial output of my alarm system. It sends out an event in a packet of 30 bytes with byte 30 being a checksum byte. There is no defined start and end byte. I'll probably need to implement a scrolling window method to find the first valid packet whereafter it should easy.
I need to be able to read this in via the SoftwareSerial library in a byte array form, and not in a char array. Having these is byte form will make my further parsing a lot easier.
Please if anyone can assist, it would be much appreciated.
robtillaart
PLease post your code sofar?
declare
uint8_t buffer[60];
if you have read 60 bytes you are sure you have captured a sequence of 30 ...
What baud rate do you use? SWserial is not the most reliable one. Is the HW serial occupied?
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
(Please do not PM for private consultancy)
