Author Topic: Programming issue on Mac (solved)  (Read 361 times)
Hello,
I have a serious issue with trying to program my Arduino on my MacBook Pro running OSX 10.8.2.
This is the verbose output trying to program the built-in blink example:
Binaire sketch-grootte: 890 bytes (van een 7.680-byte maximum)
/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/avrdude -C/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/avr/etc/avrdude.conf -v -v -v -v -patmega8 -carduino -P/dev/tty.usbmodemfa141 -b115200 -D -Uflash:w:/var/folders/tw/xv4jt_md7p76rtn173stmx040000gn/T/build3330199445503663606.tmp/Blink.cpp.hex:i
avrdude: Version 5.11, compiled on Sep  2 2011 at 18:52:52
         Copyright (c) 2007-2009 Joerg Wunsch
         System wide configuration file is "/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/avr/etc/avrdude.conf"
         User configuration file is "/Users/Pelle/.avrduderc"
         User configuration file does not exist or is not a regular file, skipping
         Using Port                    : /dev/tty.usbmodemfa141
         Using Programmer              : arduino
         Overriding Baud Rate          : 115200
avrdude: Send: 0 [30]   [20]
avrdude: Recv: . [14]
avrdude: Recv: . [10]
         AVR Part                      : ATMEGA8
         Chip Erase delay              : 10000 us
         PAGEL                         : PD7
         BS2                           : PC2
         RESET disposition             : dedicated
         RETRY pulse                   : SCK
         serial program mode           : yes
         parallel program mode         : yes
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
                                  Block Poll               Page                       Polled
           Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
           eeprom         4    20   128    0 no        512    4      0  9000  9000 0xff 0xff
           flash         33    10    64    0 yes      8192   64    128  4500  4500 0xff 0x00
           lfuse          0     0     0    0 no          1    0      0  2000  2000 0x00 0x00
           hfuse          0     0     0    0 no          1    0      0  2000  2000 0x00 0x00
           lock           0     0     0    0 no          1    0      0  2000  2000 0x00 0x00
           calibration    0     0     0    0 no          4    0      0     0     0 0x00 0x00
           signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
         Programmer Type : Arduino
         Description     : Arduino
avrdude: Send: A [41] . [80]   [20]
avrdude: Recv: . [03]
avrdude: Send: A [41] . [81]   [20]
avrdude: Recv: . [04]
avrdude: Send: A [41] . [82]   [20]
avrdude: Send: A [41] . [98]   [20]
         Hardware Version: 3
         Firmware Version: 4.4
avrdude: Send: A [41] . [84]   [20]
avrdude: Send: A [41] . [85]   [20]
avrdude: Send: A [41] . [86]   [20]
avrdude: Send: A [41] . [87]   [20]
avrdude: Send: A [41] . [89]   [20]
         Vtarget         : 0.3 V
         Varef           : 0.3 V
         Oscillator      : 28.800 kHz
         SCK period      : 3.3 us
avrdude: Send: B [42] p [70] . [00] . [00] . [01] . [01] . [01] . [01] . [02] . [ff] . [00] . [ff] . [ff] . [00] @ [40] . [02] . [00] . [00] . [00]   [20] . [00]   [20]
avrdude: Send: E [45] . [05] . [04] . [d7] . [c2] . [00]   [20]
avrdude: Send: P [50]   [20]
Reading | avrdude: Send: u [75]   [20]
avrdude: Recv: . [14] . [1e] . [95] . [0f] . [10]
################################################## | 100% 0.00s
avrdude: Device signature = 0x1e950f
avrdude: Expected signature for ATMEGA8 is 1E 93 07
         Double check chip, or use -F to override this check.
avrdude: Send: Q [51]   [20]
avrdude done.  Thank you.
Loopback test was sucessfull.
I tried programming it from a windows computer and every programe programmed just fine so i know it is a software issue on my mac.
Reinstalling Arduino IDE didn't help, countless reboots didn't work, plugging the arduino in and out didn't help.
I am in quite a loss here to what to do. This mac is my main machine so I would really like to solve this problem.
If you need more information, just ask
Thank you.
« Last Edit: January 03, 2013, 12:33:05 pm by Volta500 » Logged
Weird thing is that the output differs from time to time. Here is my last verbose output: (without compiling because of the 9500 characters limit)
This is the error I get the most
         AVR Part                      : ATMEGA8
         PAGEL                         : PD7
         BS2                           : PC2
         RETRY pulse                   : SCK
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
         Hardware Version: 3
avrdude: ser_recv(): programmer is not responding
Melbourne, Australia
Shannon Member
Lua rocks!
AVR Part                      : ATMEGA8
What sort of Arduino do you have?
It is an Arduino Uno, but I have just solved the issue.
What I did was do a search for Arduino and delete everything except my own projects.
After that I reinstalled the IDE and everything is back to normal.
There must have been some error in a configuration file that was remade in the reinstall.
Could you describe a bit more what you removed?
I'm having similar issues interfacing Due in OSX 10.8.2. I can get it to work in Windows 8 running in Parallels, see:
http://arduino.cc/forum/index.php/topic,142550.0.html
Austin, TX
CMiYC
Your problem is entirely unrelated to this one.
www.cmiyc.com - A guide to being an Enginerd
