Topic: Just got a new Mega 2560 - full of hope, but fail :( (Read 4719 times) previous topic - next topic
Melbfella
Hi Melbfella,
As far as I can tell from the bootloader code, the Mega should flash its yellow "L" LED rapidly 3 times whenever it is reset (as the Uno does).  Does yours do this when you press the reset button?  Does it also do it when you attempt to upload a sketch?
Hi Tim,
No, the Mega does not flash at all when the reset button is pressed, but my Uno and Nano do.
When I try to upload a sketch, same thing, no flashing (apart from single blink on the RX led).  However, it seems the Blink sketch is installed on it which flashes the 'L' LED red about once a second.
Thanks for your reply.
Cheers,
Doug.
