Topic: Single shot (Read 3923 times) previous topic - next topic
mrfunk
Ok thanks guys for you help... still no led though... if I pull A0 high or low :-(
This is my full code
Code: [Select]
int sensorPin = A0;            // select the input pin for the soil detector
unsigned int sensorValue = 0;  // variable to store the value coming from the soil detector
byte latch = 0;  //initial variable
  pinMode(13, OUTPUT);
  //Start Serial port
  Serial.begin(9600);        // start serial for output - for testing
  // read the value from the soil detector:
  sensorValue = analogRead(sensorPin);
  if(sensorValue<1000)
       !latch; // This detects whether the switch changed or not
       if (latch)
  LED_Burst();
}   //problem was here, you needed this
void LED_Burst() //outside of LOOP()
digitalWrite(13, HIGH);
delay(1000); // 1 second delay
digitalWrite(13, LOW);
return;
HazardsMind
#16
Jan 03, 2013, 10:24 pm Last Edit: Jan 05, 2013, 07:45 pm by HazardsMind Reason: 1
I sent you what to change. Keep in mind that what I gave you before was only meant to be pseudocode, an example, not the actual working code.
I am now a GOD member!
My GitHub:
https://github.com/AndrewMascolo?tab=repositories
PaulS
Code: [Select]
No, it doesn't. It applies the NOT operator to latch, but then you discard the result, so nothing happens. You might as well delete this statement.
Code: [Select]
Why are you using a byte variable for boolean operations? Make it clear that you MEAN boolean by using boolean. And initialize it to true or false correctly.
HazardsMind
#18
Jan 05, 2013, 06:20 pm Last Edit: Jan 05, 2013, 06:25 pm by HazardsMind Reason: 1
@everyone
Again it was only meant to be pseudo code, not a working code! The OP sent me a personal message saying it wasn't working, so it tested it myself, and it DIDN'T work. (Obviously)
So I messaged him back the actual working code, and I got back "Thankyou it works!"
@PaulS
I did and I did.
My GitHub:
