Topic: Single shot (Read 4711 times) previous topic - next topic
mrfunk
is it possible to make a switch "Single Shot" with arduino...  I.e it gives a high  once.. even when the input is held high... it wont set an op high again until the switch is released and set high?
any ideas..
i want to make a soil meter which triggers an led once when the soil is dry. not latched.
i fully understand the analogue side,   but not how to mke it single shot, other than use delays..
AWOL
Yes, just don't put an "else" clause in your "if" statement.
spycatcher2k
Follow this logic :
if I read high - set (triggered=TRUE)
if I read low while triggered=TRUE set (triggered=FALSE)
if triggered=HIGH and done=FALSE - DO SOMETHING,then set done=TRUE
start again
Hope this helps
http://www.uk-pcb.co.uk - UK Based PCB Fab & Assembly Company
Design & Assembly work undertaken - Arduino repairs & testing - PM for details. Arduino & C# PC programming.
mrfunk
Ok so could you apply your thery to this
int sensorPin = A0;            // select the input pin for the soil detector
unsigned int sensorValue = 0;  // variable to store the value coming from the soil detector
  pinMode(13, OUTPUT);
  //Start Serial port
  Serial.begin(9600);        // start serial for output - for testing
  // read the value from the soil detector:
  sensorValue = analogRead(sensorPin);
  if(sensorValue<400) digitalWrite(13, HIGH);   // set the LED on
  else digitalWrite(13, LOW);   // set the LED on
I want the led just to blink once say 1 second  even if the input condition stays the same..  obviously if the input changed >400 then this should reset..
does this make any sense..
please help
david
HazardsMind
#4
Jan 03, 2013, 04:25 pm Last Edit: Jan 03, 2013, 04:27 pm by HazardsMind Reason: 1
Pseudo example:
byte latch = 0;  //initial variable
If(switch == HIGH) {  //looks at the switch, if it is high for the first time, LED is ON. If the switch changes then goes high again, LED is OFF
!latch; // This detects whether the switch changed or not.
latch ? (do this if TRUE) : (do this if FALSE);  //conditional statement,  compressed IF/ELSE statement
My GitHub:
https://github.com/AndrewMascolo?tab=repositories
mrfunk
Pseudo example:
thankss for the quick reply "the penny is satrting to drop" ;-)
please could you modify my analogue code so I can see where this drops in..
Cheers david.
HazardsMind
#6
Jan 03, 2013, 04:55 pm Last Edit: Jan 03, 2013, 04:56 pm by HazardsMind Reason: 1
just replace switch == HIGH with sensorValue<400 and replace (do this if TRUE) with digitalWrite(13, HIGH) and likewise for (do this if false).
We only provide examples, the rest is up to you.
My GitHub:
mrfunk
  //Start Serial port
  if(sensorValue<400)
latch ? (digitalwrite(13, HIGH) : (digitalWrite(13, LOW);  //conditional statement,  compressed IF/ELSE statement
is this correct.. not sure on the brackets?
so in thery  the lED will come on oonce,, will it go off if the input is still high?  as this is what i want just a blip from the led.. i.e not on continuous if the input is held in the <400 condition.
cheers david
HazardsMind
#8
Jan 03, 2013, 05:22 pm Last Edit: Jan 03, 2013, 05:33 pm by HazardsMind Reason: 1
You want the led on just once? then this is not for you. You want
if(sensorValue<400)
latch ? LED_Burst()  : (/*Just smile and wave*/ );  //conditional statement,  compressed IF/ELSE statement
void LED_Burst() //outside of LOOP()
digitalwrite(13, HIGH);
delay(1000); // 1 second delay
return;
"byte latch" must be moved and go up with sensorPin and sensorValue
My GitHub:
mrfunk
  //Start Serial port
  if(sensorValue<400)
return;
so is this correct?  I do hope so.. sorry just learning the ropes
HazardsMind
Your missing a closing bracket somewhere in your loop()
My GitHub:
mrfunk
So close.. can't see the mistake ;-(
HazardsMind
  if(sensorValue<400)
}   //problem was here, you needed this
If you tried to compile it in the arduino software, you would have gotten an error in the LOOP() telling you, you need a closing bracket " } " before void LED_Burst()
My GitHub:
mrfunk
still getting an error
sketch_jan03a.ino: In function 'void loop()':
sketch_jan03a:18: error: expected primary-expression before ')' token
what needs to go here?  (in BOLD)
       latch ? LED_Burst()  : ([b]/*Just smile and wave*/ [/b]);  //conditional statement,  compressed IF/ELSE statement
Arrch
That's a gross misuse of the ternary operator; it's much more simply written like this:
if (latch)
  LED_Burst();
