Author Topic: rf433 using an fs1000a as stransmitter  (Read 880 times)
Hi There,
I am using an RF433 receiver (RX) and another RF433 transmitter (TX) labelled FS1000a.
I plugged them on 2 different arduino's.
Works all fine to send simple datas with the help of virtualwire library.
However, I also own and RFXTRX433 product from RFXCOM to manage my domotic products (temp, humidity, outlets, etc sensors using mainly oregon and x10 protocols).
I now would like to be able to send datas (using my FS1000a component) to my RFXTRX433 device.
My rfxcom device does not seen any incoming trafic (it can read undecoded frames, not only well formed frames).
My arduino receiver does not see any incoming trafic either from my rfxcom devices.
All these being on 433mhz, I would have thought I should have been able to catch some trafic there and then "simply" have to encode/decode it?
You can see picture of my arduino receiver & trasmitter here : http://www.nerdegutta.org/index.php/linux/140-rf-txrx-with-fs1000a-and-xy-mk-5v .
Any idea welcome,
Thanks smiley
Erwan
Anaheim CA.
Experienced old Whitebeard with a Full head of Hair...
There are several different types of "433 MHz" Transmitters. The typical cheap 433 MHz transmitter is a fixed frequency device. The other device is either on another of 5 (I think) frequencies or it is a synthesized transceiver device that uses a different baud rate (much) or protocol as you get nothing from the FS1000a receiver which is a pair to the simple OOK transmitter and not to your more sophisticated remote control transmitter.
Bob
“The solution of every problem is another problem.” -Johann Wolfgang von Goethe
@Docedison : Thanks for the feedback.
This is a dead end then? no hope with my cheap fs1000a transmitter?
either the frequency is not good or the baud rate (which i can however tweak with virtualwire nop?).
thx,
Erwan
Could be usefull to others, I managed to receive oregon datas, just like my rfxtrx433 does, using this page : http://connectingstuff.net/blog/decodage-protocole-oregon-arduino-1/ .
Next step is sending datas.
The sketch to receive datas (from the above url) :
(it is important to use digital pin 3 for the interrupt.
// Oregon V2 decoder modfied - Olivier Lebrun
// Oregon V2 decoder added - Dominique Pierre
// New code to decode OOK signals from weather sensors, etc.
// 2010-04-11 <jcw@equi4.com> http://opensource.org/licenses/mit-license.php
// $Id: ookDecoder.pde 5331 2010-04-17 10:45:17Z jcw $
class DecodeOOK {
protected:
    byte total_bits, bits, flip, state, pos, data[25];
    virtual char decode (word width) =0;
public:
    enum { UNKNOWN, T0, T1, T2, T3, OK, DONE };
    DecodeOOK () { resetDecoder(); }
    bool nextPulse (word width) {
        if (state != DONE)
            switch (decode(width)) {
                case -1: resetDecoder(); break;
                case 1:  done(); break;
        return isDone();
    bool isDone () const { return state == DONE; }
    const byte* getData (byte& count) const {
        count = pos;
        return data;
    void resetDecoder () {
        total_bits = bits = pos = flip = 0;
        state = UNKNOWN;
    // add one bit to the packet data buffer
    virtual void gotBit (char value) {
        total_bits++;
        byte *ptr = data + pos;
        *ptr = (*ptr >> 1) | (value << 7);
        if (++bits >= 8) {
            bits = 0;
            if (++pos >= sizeof data) {
                resetDecoder();
                return;
        state = OK;
    // store a bit using Manchester encoding
    void manchester (char value) {
        flip ^= value; // manchester code, long pulse flips the bit
        gotBit(flip);
    // move bits to the front so that all the bits are aligned to the end
    void alignTail (byte max =0) {
        // align bits
        if (bits != 0) {
            data[pos] >>= 8 - bits;
            for (byte i = 0; i < pos; ++i)
                data[i] = (data[i] >> bits) | (data[i+1] << (8 - bits));
            bits = 0;
        // optionally shift bytes down if there are too many of 'em
        if (max > 0 && pos > max) {
            byte n = pos - max;
            pos = max;
                data[i] = data[i+n];
    void reverseBits () {
        for (byte i = 0; i < pos; ++i) {
            byte b = data[i];
            for (byte j = 0; j < 8; ++j) {
                data[i] = (data[i] << 1) | (b & 1);
                b >>= 1;
    void reverseNibbles () {
            data[i] = (data[i] << 4) | (data[i] >> 4);
    void done () {
        while (bits)
            gotBit(0); // padding
        state = DONE;
class OregonDecoderV2 : public DecodeOOK {
  public:
    OregonDecoderV2() {}
        if(!(total_bits & 0x01))
            data[pos] = (data[pos] >> 1) | (value ? 0x80 : 00);
        total_bits++;
        pos = total_bits >> 4;
        if (pos >= sizeof data) {
            Serial.println("sizeof data");
            resetDecoder();
            return;
        state = OK;
    virtual char decode (word width) {
       if (200 <= width && width < 1200) {
            //Serial.println(width);
            byte w = width >= 700;
            switch (state) {
                case UNKNOWN:
                    if (w != 0) {
                        // Long pulse
                        ++flip;
                    } else if (w == 0 && 24 <= flip) {
                        // Short pulse, start bit
                        flip = 0;
                        state = T0;
                        // Reset decoder
                        return -1;
                    break;
                case OK:
                    if (w == 0) {
                        // Short pulse
                        state = T0;
                        // Long pulse
                        manchester(1);
                    break;
                case T0:
                    if (w == 0) {
                      // Second short pulse
                        manchester(0);
                        // Reset decoder
                        return -1;
                    break;
        } else if (width >= 2500  && pos >= 8) {
            return 1;
            return -1;
        return 0;
OregonDecoderV2 orscV2;
volatile word pulse;
void ext_int_1(void)
    static word last;
    // determine the pulse length in microseconds, for either polarity
    pulse = micros() - last;
    last += pulse;
float temperature(const byte* data)
    int sign = (data[6]&0x8) ? -1 : 1;
    float temp = ((data[5]&0xF0) >> 4)*10 + (data[5]&0xF) + (float)(((data[4]&0xF0) >> 4) / 10.0);
    return sign * temp;
byte humidity(const byte* data)
    return (data[7]&0xF) * 10 + ((data[6]&0xF0) >> 4);
// Ne retourne qu'un apercu de l'etat de la baterie : 10 = faible
byte battery(const byte* data)
    return (data[4] & 0x4) ? 10 : 90;
byte channel(const byte* data)
    byte channel;
    switch (data[2])
        case 0x10:
            channel = 1;
            break;
        case 0x20:
            channel = 2;
            break;
        case 0x40:
            channel = 3;
            break;
     return channel;
void reportSerial (const char* s, class DecodeOOK& decoder)
    byte pos;
    const byte* data = decoder.getData(pos);
    Serial.print(s);
    Serial.print(' ');
        Serial.print(data[i] >> 4, HEX);
        Serial.print(data[i] & 0x0F, HEX);
    // Outside/Water Temp : THN132N,...
    if(data[0] == 0xEA && data[1] == 0x4C)
       Serial.print("[THN132N,...] Id:");
       Serial.print(data[3], HEX);
       Serial.print(" ,Channel:");
       Serial.print(channel(data));
       Serial.print(" ,temp:");
       Serial.print(temperature(data));
       Serial.print(" ,bat:");
       Serial.print(battery(data));
       Serial.println();
    // Inside Temp-Hygro : THGR228N,...
    else if(data[0] == 0x1A && data[1] == 0x2D)
       Serial.print("[THGR228N,...] Id:");
       Serial.print(" ,hum:");
       Serial.print(humidity(data));
       Serial.println();
    decoder.resetDecoder();
void setup ()
    Serial.println("\n[ookDecoder]");
    attachInterrupt(1, ext_int_1, CHANGE);
    //DDRE  &= ~_BV(PE5); //input with pull-up
    //PORTE &= ~_BV(PE5);
void loop () {
    static int i = 0;
    cli();
    word p = pulse;
    pulse = 0;
    sei();
    if (p != 0)
        if (orscV2.nextPulse(p))
            reportSerial("OSV2", orscV2);
