Loading...
Pages: [1]   Go Down
Author Topic: Motor library & driver compatibility  (Read 197 times)
Offline Offline
Newbie
View Profile
I am trying to use the Adafruit motor library with my Arduino Mega and the Adafruit motor shield.  From what I know, I think the library is only compatible with older versions of the Arduino software.  However, I have tried using version 1.0, and that didn't work.  I have already installed the newer drivers for the Arduino, and that seems to be the problem.  Is there a way that I can reset the drivers so that I can install an older one from the 1.0 release?  Thanks.
Logged
Offline Offline
Edison Member
View Profile
The Adafruit Library is also written for the Arduino Mega.
Why would it not be compatible ? In the source code the code is adapted for version 1.00 and above. So it should work with the newest 1.0.3.
Do you have a Arduino Uno ? Perhaps you could try that.
Adafruit Motor Shield : http://www.ladyada.net/make/mshield/use.html
Alternative Sketch : http://playground.arduino.cc/Main/AdafruitMotorShield
Logged
Pages: [1]   Go Up
Print
Jump to:
