Hello!
I have successfully installed and used the ATtiny extensions using the Arduino Uno as a programmer. First I programmed a skeleton to use i2c and the only thing the sketch does is assigning a slave address to the ATtiny85. I connected everything to the Raspberry Pi and was able to detect the chip on the bus at address 0x26. Second I transferred the sample sketch "Tiny85_I2C_Slave_Ex". I then again connected everything to the Raspberry Pi.
When I run
i2cdetect to see what is connected and which addresses are used I get:
pi@raspberrypi ~ $ i2cdetect -y 1
0 1 2 3 4 5 6 7 8 9 a b c d e f
00: -- -- -- -- -- -- -- -- -- -- -- -- --
10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
20: 20 -- -- -- -- -- 26 -- -- -- -- -- -- -- -- --
30: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
50: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
60: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
70: -- -- -- -- -- -- -- --
Then I write and read from the ATtiny using
i2cget. The LED flashes but instead of adding 10 to the written value and returning the new value it returns reads 0x00. When I run the sketch a second time it does not work anymore.
pi@raspberrypi ~ $ i2cget -y 1 0x26 0x01 c
0x00
When I run
i2cdetect again the ATtiny after executing the sketch once seems to have flushed the bus taking all addresses. I get:
00: 03 04 05 06 07 08 09 0a 0b 0c 0d 0e 0f
10: 10 11 12 13 14 15 16 17 18 19 1a 1b 1c 1d 1e 1f
20: 20 21 22 23 24 25 26 27 28 29 2a 2b 2c 2d 2e 2f
30: 30 31 32 33 34 35 36 37 38 39 3a 3b 3c 3d 3e 3f
40: 40 41 42 43 44 45 46 47 48 49 4a 4b 4c 4d 4e 4f
50: 50 51 52 53 54 55 56 57 58 59 5a 5b 5c 5d 5e 5f
60: 60 61 62 63 64 65 66 67 68 69 6a 6b 6c 6d 6e 6f
70: 70 71 72 73 74 75 76 77
pi@raspberrypi ~ $
I have tried several chips, tried it on a breadboard on a PCB but the result is always the same. I do not use any pullup resistors since the Raspberry Pi provides them. I added them but with no change of the results. I tried a different sketch for reading and writing from the bus and the same happens. So it has obviously nothing to do with the sketch but with a) the ATtiny85 in general or b) the TinyWire library.
Has anyone seen something similar? Are their known bugs? Or am I simply to unexperienced?
Thanks for reading! Thanks for any help!
Greetings,
Moritz
