Topic: Nokia 5110 & Adafruit library (Read 7491 times) previous topic - next topic
he3r0
Jan 04, 2013, 01:54 am Last Edit: Jan 06, 2013, 11:11 am by he3r0 Reason: 1
Hi. I'm trying to display bitmaps from my Mega 2560 on my Nokia 5110 LCD by means of Adafruit libs.
I was able to use it without bigger issues to draw lines, shapes, etc. as here -> http://muziol.com/nokialcd/
however for some reason i cant't get it to display my bitmap.
I've found and modified code displaying Nyan cat,  and that works, though it does not use Adafruit library.
September 5th, 2011
Wade Smith
Based on code by Nathan Seidle
This code is free and open, like NyanCat
Written for the Nokia 5110 84x48 graphic LCD:
http://www.sparkfun.com/products/10168
http://www.adafruit.com/products/338
#define PIN_SCE   7
#define PIN_RESET 6
#define PIN_DC    5
#define PIN_SDIN  4
#define PIN_SCLK  3
//The DC pin tells the LCD if we are sending a command or data
#define LCD_COMMAND 0
#define LCD_DATA  1
//You may find a different size screen, but this one is 84 by 48 pixels
#define LCD_X     84
#define LCD_Y     48
char frame1[] = {
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x20, 0x20, 0x60, 0x60, 0xE0,
0xE0, 0xE0, 0xE0, 0xE0, 0xE0, 0xE0, 0xE0, 0xE0, 0xE0, 0xE0, 0xE0, 0xE0, 0xE0, 0xE0, 0xE0, 0xE0,
0xE0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x80, 0xE0, 0xE0, 0xE0, 0xE0, 0xE0, 0xE0,
0xE0, 0xE0, 0xE0, 0xE0, 0xE0, 0xE0, 0xE0, 0xE0, 0xE0, 0xE0, 0xE0, 0x60, 0x60, 0x20, 0x20, 0x00,
0x00, 0x00, 0x00, 0x00, 0x01, 0x03, 0x07, 0x1F, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF,
0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFE, 0xFC, 0xFC, 0xFC, 0xF8, 0xF8, 0xF8, 0xF8, 0xFC, 0xFF,
0xFE, 0xFE, 0xFF, 0xFC, 0xF8, 0xF8, 0xF8, 0xF8, 0xFC, 0xFC, 0xFC, 0xFE, 0xFF, 0xFF, 0xFF, 0xFF,
0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0x3F, 0x0F, 0x03, 0x01, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x07, 0x03, 0x03, 0x03,
0x03, 0x03, 0x03, 0x03, 0x07, 0x07, 0x07, 0x07, 0x07, 0x07, 0x0F, 0x0F, 0x0F, 0x1F, 0x1F, 0x3F,
0x3F, 0x7F, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0x7F, 0x7F, 0x3F, 0x1F, 0x1F, 0x0F, 0x0F, 0x0F,
0x07, 0x07, 0x07, 0x07, 0x07, 0x07, 0x03, 0x03, 0x03, 0x03, 0x03, 0x03, 0x03, 0x07, 0x04, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0x07, 0x07, 0x03, 0x00, 0x00, 0x00, 0x00, 0x00,
void setup(void) {
 LCDInit(); //Init the LCD
void loop(void) {
 LCDBitmap(frame1);
void gotoXY(int x, int y) {
 LCDWrite(0, 0x80 | x);  // Column.
 LCDWrite(0, 0x40 | y);  // Row.  ?
void LCDBitmap(char my_array[]){
 for (int index = 0 ; index < (LCD_X * LCD_Y / 8) ; index++)
   LCDWrite(LCD_DATA, my_array[index]);
void LCDClear(void) {
   LCDWrite(LCD_DATA, 0x00);
 gotoXY(0, 0);
//This sends the magical commands to the PCD8544
void LCDInit(void) {
 //Configure control pins
 pinMode(PIN_SCE, OUTPUT);
 pinMode(PIN_RESET, OUTPUT);
 pinMode(PIN_DC, OUTPUT);
 pinMode(PIN_SDIN, OUTPUT);
 pinMode(PIN_SCLK, OUTPUT);
 //Reset the LCD to a known state
 digitalWrite(PIN_RESET, LOW);
 digitalWrite(PIN_RESET, HIGH);
 LCDWrite(LCD_COMMAND, 0x21); //Tell LCD that extended commands follow
 LCDWrite(LCD_COMMAND, 0xB0); //Set LCD Vop (Contrast): Try 0xB1(good @ 3.3V) or 0xBF if your display is too dark
 LCDWrite(LCD_COMMAND, 0x04); //Set Temp coefficent
 LCDWrite(LCD_COMMAND, 0x14); //LCD bias mode 1:48: Try 0x13 or 0x14
 LCDWrite(LCD_COMMAND, 0x20); //We must send 0x20 before modifying the display control mode
 LCDWrite(LCD_COMMAND, 0x0C); //Set display control, normal mode. 0x0D for inverse
//There are two memory banks in the LCD, data/RAM and commands. This
//function sets the DC pin high or low depending, and then sends
//the data byte
void LCDWrite(byte data_or_command, byte data) {
 digitalWrite(PIN_DC, data_or_command); //Tell the LCD that we are writing either to data or a command
 //Send the data
 digitalWrite(PIN_SCE, LOW);
 shiftOut(PIN_SDIN, PIN_SCLK, MSBFIRST, data);
 digitalWrite(PIN_SCE, HIGH);
and I'm getting correct bitmap on lcd
***continued in next post.
he3r0
#1
Jan 04, 2013, 01:55 am Last Edit: Jan 06, 2013, 11:12 am by he3r0 Reason: 1
but after I tried to use adafruit library, code looks like that
#include <Adafruit_GFX.h>
#include <Adafruit_PCD8544.h>
Adafruit_PCD8544 display = Adafruit_PCD8544(3, 4, 5, 7, 6);
static unsigned char __attribute__ ((progmem)) LOGObmp[]={
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,  };
void setup()   {
 display.begin();
 display.display();
 display.setContrast(40);
 display.clearDisplay();
display.drawBitmap(0 , 0, LOGObmp , 84, 48, BLACK);
display.display();
and displayed bitmap looks like that
Can someone please help me to sort out that usage of Adafruit library ?
DerekD
If you're not firm on your use of the Adafruit library, there is another library that I've had success with.  There is a link to an online image converter in the "notes" section under "drawBitmap toward the bottom.
http://www.henningkarlsen.com/electronics/library.php?id=44
he3r0
The only thing that gives me troubles in Adafruit library, are said bitmaps, everything works pretty nice.
But thank you for the link, I'll definitely give it a try.
Slaymantis
I also have the same issue with that Adafruit library giving me the muddled image on the screen.
Drugovi
Hello,
I use the Adafruit library too and it seems that you must save the bitmap in binary format, like this:
The image to binary converter I use is this one https://github.com/Rodot/BitmapEncoder
const byte arduLogo[] PROGMEM = {                                              // width 40, height 32
B00000000,B00000000,B00000000,B00000000,B01111110,
B00000000,B00000000,B00000000,B00000000,B00101110,
B00000000,B00000000,B00000000,B00000000,B00101010,
B00000001,B11111000,B00000000,B00001111,B10000000,
B00000111,B11111110,B00000000,B00111111,B11100000,
B00011111,B11111111,B10000000,B11111111,B11111000,
B00111111,B00000111,B11000001,B11110000,B11111100,
B00111100,B00000011,B11100011,B11100000,B00111100,
B01111000,B00000000,B11110111,B10000000,B00011110,
B01110000,B00000000,B01110111,B00000110,B00001110,
B11100000,B00000000,B00111110,B00000110,B00000111,
B11100001,B11111000,B00111110,B00011111,B10000111,
B11100001,B11111000,B00011100,B00011111,B10000111,
B11110000,B00000000,B00111110,B00000110,B00001111,
B01110000,B00000000,B01110111,B00000000,B00001110,
B00111111,B00001111,B11000001,B11110000,B11111100,
B00011111,B11111111,B00000000,B11111111,B11111000,
B00000111,B11111100,B00000000,B00111111,B11100000,
B00000001,B11110000,B00000000,B00001111,B10000000,
B00000000,B00000000,B00000000,B00000000,B00000000,
B01110011,B11001111,B00100010,B11100100,B01001110,
B10001010,B00101000,B10100010,B01000100,B01010001,
B10001010,B00101000,B10100010,B01000110,B01010001,
B11111011,B11001000,B10100010,B01000101,B01010001,
B10001010,B10001000,B10100010,B01000100,B11010001,
B10001010,B01001000,B10100010,B01000100,B01010001,
B10001010,B00101111,B00011100,B11100100,B01001110,
