Topic: Problem with interrupts (Read 937 times) previous topic - next topic
pt_t
Jan 04, 2013, 03:34 am Last Edit: Jan 04, 2013, 04:23 am by Coding Badly Reason: 1
hi i'm new with arduino and i have a problem with interrupts, i was testing this code:
int pin = 10;
volatile int state = LOW;
  pinMode(pin, OUTPUT);
  attachInterrupt(0, blink, CHANGE);
  digitalWrite(pin, state);
void blink()
  state = !state;
but im not sure about why the led change when i connect to ground, if i conect to 5 volts nothing happens, i have an arduinomega
thanks
Moderator edit: [code] [/code] tags added.
MarkT
1) code tags please!
2) connect _what_ to 5V or ground?  where is the LED?
pt_t
sorry for the code tags,  and i  connected  the interrupt pin (pin2) to 5v, this is like a sensor signal i think ,so why does not activate the interrupt ???
and the led is on pin10
thanks
JimboZA
Do you know if the LED actually works? It starts off LOW.... if it's faulty then it might be trying to go on when you apply the interrupt but you can't see it.
Maybe change the line volatile int state = LOW; to volatile int state = HIGH; so it starts in the "on" state and you'll be confident it actually works.
Johannesburg hams call me: ZS6JMB on Highveld rep 145.7875 (-600 & 88.5 tone)
Dr Perry Cox: "Help me to help you, help me to help you...."
Your answer may already be here: https://forum.arduino.cc/index.php?topic=384198.0
pt_t
thank you jimboza, I tried your idea, but the LED works well, and something strange happens when I connect pin2 to ground, changes state   :S
Nick Gammon
If you move pin 2 from Gnd to +5V (and back) does the LED toggle?
More info:
JimboZA
...and something strange happens ...
And what is that strange thing?
pt_t
if I connect the ground to pin2    the state of LED changes  or just connect a wire to pin2( i dont know why) , but if a connect 5 volts and back nothings append .....
and now I'm testing on  RISING mode
is it clear? maybe my English is another problem xD
Nick Gammon
The pin needs a defined state. Just connecting and disconnecting a wire is not that. Enable the internal pull-ups, or use an external resistor.
More info:
