Topic: not declared in this scope (Read 2455 times) previous topic - next topic
injeckshun
My "setup" and "loop" from "void loop()" and "voidsetup()" aren't bold...
they used to always be whenever i typed them into the ide.
Also now there is an error message saying
"ledOn' was not declared in this scope"
int switchPin = 8;
int ledPin = 13;
boolean lastButton = LOW;
boolean ledOn = false;
  pinMode(switchPin, INPUT);
  pinMode(ledPin, OUTPUT);
   if(digitalRead(switchPin) == HIGH && lastButton == LOW)
     ledON = !ledON;
    lastButton = HIGH;
     lastButton = digitalRead(switchPin);
   digitalWrite(ledPin,ledON);
Coding Badly
...lower case n
     ledON = !ledON;
...upper case N
ematson5897
The error message is because you declare it as ledOn, with a lowercase n, but try to use ledON, with an uppercase N.
ematson5897
MarkT
Indeed you have to spell consistently including case to program.  Or use an editor with auto-complete on variable names.
UKHeliBob
I would be interested in such an editor.  Can you recommend one ?
injeckshun
thanks so much to everyone, obviously i am new to miss something like this, but i am just following what all these tutorials tell me to do so i can learn the language. i knew here would be the place to come, any other forum if you ask a simple question they just bash you and give you no answers.. guess i couldve figured it out haha sometimes you need a fresh set of eyes
PaulS
If that's what you wanted, why didn't you say so?  8)
glenmcmurchy
Im having a similar problem, however i have checked the capital letters and I can't seem to find why LedOn was not declared in scope. :/
Here is my Code:
int switchPin = 8;
int ledPin = 13;
boolean currentButton = LOW;
void setup ()
  pinMode (switchPin, INPUT);
  pinMode (ledPin, OUTPUT);
boolean debounce(boolean last)
  boolean current = digitalRead(switchPin);
  if (last != current)
    delay(5);
return current;
void loop ()
  currentButton = debounce(lastButton);
  if (lastButton == LOW  && currentButton == HIGH)
    ledOn = !ledOn;
    lastButton = currentButton;
  digitalWrite (ledPin, LedOn);
ellinnaj04
contains small letter 'l' while
you use capital 'L' on
glenmcmurchy
aw god I would have sworn I had checked every inch of it as well! thanks a lot haha :))) :D  :D
ellinnaj04
no problem.. it also happens to me sometimes..
RayLivingston
Why anyone uses the Arduino IDE is beyond me.  Get AtmelStudio, and get the free VisualMicro plug-in, and you have a modern development environment based on Microfost VisualStudio that works really well.  When you get a compiler error, simply double-click on the error message, and it takes you right to the line that caused the error.  If has "Intellisense", so will auto-complete variabe and function names for you.  It uses the Arduino tools to do the build, so it is 100% compatible with the Arduino IDE.
Regards,
Ray L.
