Author Topic: clock (second and minutes)  (Read 347 times)
i need make clock display second and minutes using arduino UNO R3
Cape Town South Africa
A newbie with loads of posts, and still so much to learn !
do a search in the box at the top of this page  for "clock display "  or similar, there have been many projects to give you ideas
We live in the era of the smart phones and stupid people.
how i can set timer in arduino
You can either go through the examples and learn gradually,  or you can post on the " gigs and collaborations " and see if someone will design it for you for money.
Seattle, WA USA
Seattle, WA USA
Why do you think you need to?
There are 10 types of people in this world; those that understand binary numbers and those that don't.
Does this help?
** Arduino sketch to display date, time temperature and humidity.
** Uses LCD2004 display, Tiny RTC and DHT11 temperature and humidity sensor.
** All parts are readily found on eBay
** NOTES:
**    I2C pins are A4 SDA, A5 SCL on UNO, 20 SDA and 21 SCL on MEGA 2560.
**    DHT11 data connects to Pin 12.
**    Displays time in 12 hour format.
**    Only reads DHT11 sensor every x seconds for smooth time updating
** Written by Kuhntucker
** LICENSE: GNU General Public License, version 3 (GPL-3.0)
unsigned long readint=15; //Read DHT11 every readint seconds.
unsigned long lasttemptime; //Used to restrict reading DHT11 to every readint seconds.
#include <Wire.h>
#include <RTClib.h>
#include "DHT.h"
#define I2C_ADDR    0x3F  // Define I2C Address where the SainSmart LCD is
#define BACKLIGHT_PIN     3
#define En_pin  2
#define Rw_pin  1
#define Rs_pin  0
#define D4_pin  4
#define D5_pin  5
#define D6_pin  6
#define D7_pin  7
LiquidCrystal_I2C   lcd(I2C_ADDR,En_pin,Rw_pin,Rs_pin,D4_pin,D5_pin,D6_pin,D7_pin);
#define DHTPIN 12     // DHT11 Data Pin
#define DHTTYPE DHT11   // For DHT 11 sensor
DHT dht(DHTPIN, DHTTYPE);
RTC_DS1307 RTC;
  lcd.begin (20,4);
  Wire.begin();
  RTC.begin();
  //Set the clock to the date & time this sketch was compiled.
  if (! RTC.isrunning()) {
     RTC.adjust(DateTime(__DATE__, __TIME__));
  // Switch on the backlight and prep the LCD
  lcd.setBacklightPin(BACKLIGHT_PIN,POSITIVE);
  lcd.setBacklight(HIGH);
  lcd.clear();
  lcd.home ();
  writetemphumid(0,2);  //wwrites initial temp and humidity
  lasttemptime=millis();
} //End setup
  writedate(0,0);
  writetime(0,1);
  if(millis()-lasttemptime>1000*readint) //Reads DHT11 every readint seconds
  if(millis()<lasttemptime) //Resets lasttemptime and reads DHT11 on millis() rollover, ~every 49 days.
    lcd.print("did it");
}  //End Loop
//function to write the time
void writetime(int col, int row)
  byte timehour;
  DateTime now = RTC.now(); //read the clock
  timehour = byte(now.hour());
  lcd.setCursor (col, row);
  if (timehour>12) timehour=(timehour-12);
  if (timehour==0) timehour=12;
  lcd.print(timehour, DEC);
  lcd.print(':');
  if (now.minute()<=9) lcd.print("0");
  lcd.print(now.minute(), DEC);
  lcd.print(':');
  if (now.second()<=9) lcd.print("0");
  lcd.print(now.second(), DEC);
  lcd.print(" ");
  if (now.hour()>12) lcd.print("PM  "); else lcd.print("AM  ");
}  //End writetime
//function to write the date
void writedate(int col, int row)
  int daynumber;
  char* weekday[]={"Sunday=0 ", "Monday ", "Tuesday ", "Wednesday ",
                  "Thursday ", "Friday ", "Saturday ", "Sunday=1 "};
  if (now.hour()==0 && now.minute()==0 && now.second()<2)
    lcd.setCursor(col, row);
    lcd.print("                    ");
  daynumber = now.dayOfWeek();
  lcd.print(weekday[daynumber]);
  if (now.month()<=9) lcd.print("0");
  lcd.print(now.month(), DEC);
  lcd.print('/');
  if (now.day()<=9) lcd.print("0");
  lcd.print(now.day(), DEC);
  lcd.print('/');
  lcd.print(now.year(), DEC);
}  //End writedate
//function to write temperature and humidity
void writetemphumid (int col, int row)
  float h = dht.readHumidity();
  float t = dht.readTemperature();
  // check if returns are valid, if they are NaN (not a number) then something went wrong!
  if (isnan(t) || isnan(h))
    lcd.setCursor(col,row);
    lcd.print("Failed to read from DHT");
   else {
    t=(9.0*t/5.0)+32.0;
    lcd.print("Temp: ");
    lcd.print(int(t));
    lcd.print(" F");
    lcd.setCursor ( 0, (row+1));
    lcd.print("Humidity: ");
    lcd.print(int(h));
    lcd.print("%");
}  //Endwritetemphumid
After you Paul .. :-)
