Topic: clock (second and minutes) (Read 1 time) previous topic - next topic
MostafaHamdy
i need make clock display second and minutes using arduino UNO R3
John_Smith
do a search in the box at the top of this page  for "clock display "  or similar, there have been many projects to give you ideas
45 years of editing projects with a knife and soldering iron, then I found Arduino !
MostafaHamdy
how i can set timer in arduino
John_Smith
You can either go through the examples and learn gradually,  or you can post on the " gigs and collaborations " and see if someone will design it for you for money.
PaulS
Why do you think you need to?
kuhntucker
Does this help?
** Arduino sketch to display date, time temperature and humidity.
** Uses LCD2004 display, Tiny RTC and DHT11 temperature and humidity sensor.
** All parts are readily found on eBay
** NOTES:
**    I2C pins are A4 SDA, A5 SCL on UNO, 20 SDA and 21 SCL on MEGA 2560.
**    DHT11 data connects to Pin 12.
**    Displays time in 12 hour format.
**    Only reads DHT11 sensor every x seconds for smooth time updating
** Written by Kuhntucker
** LICENSE: GNU General Public License, version 3 (GPL-3.0)
unsigned long readint=15; //Read DHT11 every readint seconds.
unsigned long lasttemptime; //Used to restrict reading DHT11 to every readint seconds.
#include <Wire.h>
#include <RTClib.h>
#include "DHT.h"
#define I2C_ADDR    0x3F  // Define I2C Address where the SainSmart LCD is
#define BACKLIGHT_PIN     3
#define En_pin  2
#define Rw_pin  1
#define Rs_pin  0
#define D4_pin  4
#define D5_pin  5
#define D6_pin  6
#define D7_pin  7
LiquidCrystal_I2C   lcd(I2C_ADDR,En_pin,Rw_pin,Rs_pin,D4_pin,D5_pin,D6_pin,D7_pin);
#define DHTPIN 12     // DHT11 Data Pin
#define DHTTYPE DHT11   // For DHT 11 sensor
DHT dht(DHTPIN, DHTTYPE);
RTC_DS1307 RTC;
  lcd.begin (20,4);
  Wire.begin();
  RTC.begin();
  //Set the clock to the date & time this sketch was compiled.
  if (! RTC.isrunning()) {
     RTC.adjust(DateTime(__DATE__, __TIME__));
  // Switch on the backlight and prep the LCD
  lcd.setBacklightPin(BACKLIGHT_PIN,POSITIVE);
  lcd.setBacklight(HIGH);
  lcd.clear();
  lcd.home ();
  writetemphumid(0,2);  //wwrites initial temp and humidity
  lasttemptime=millis();
} //End setup
  writedate(0,0);
  writetime(0,1);
  if(millis()-lasttemptime>1000*readint) //Reads DHT11 every readint seconds
  if(millis()<lasttemptime) //Resets lasttemptime and reads DHT11 on millis() rollover, ~every 49 days.
    lcd.print("did it");
}  //End Loop
//function to write the time
void writetime(int col, int row)
  byte timehour;
  DateTime now = RTC.now(); //read the clock
  timehour = byte(now.hour());
  lcd.setCursor (col, row);
  if (timehour>12) timehour=(timehour-12);
  if (timehour==0) timehour=12;
  lcd.print(timehour, DEC);
  lcd.print(':');
  if (now.minute()<=9) lcd.print("0");
  lcd.print(now.minute(), DEC);
  lcd.print(':');
  if (now.second()<=9) lcd.print("0");
  lcd.print(now.second(), DEC);
  lcd.print(" ");
  if (now.hour()>12) lcd.print("PM  "); else lcd.print("AM  ");
}  //End writetime
//function to write the date
void writedate(int col, int row)
  int daynumber;
  char* weekday[]={"Sunday=0 ", "Monday ", "Tuesday ", "Wednesday ",
                  "Thursday ", "Friday ", "Saturday ", "Sunday=1 "};
  if (now.hour()==0 && now.minute()==0 && now.second()<2)
    lcd.setCursor(col, row);
    lcd.print("                    ");
  daynumber = now.dayOfWeek();
  lcd.print(weekday[daynumber]);
  if (now.month()<=9) lcd.print("0");
  lcd.print(now.month(), DEC);
  lcd.print('/');
  if (now.day()<=9) lcd.print("0");
  lcd.print(now.day(), DEC);
  lcd.print('/');
  lcd.print(now.year(), DEC);
}  //End writedate
//function to write temperature and humidity
void writetemphumid (int col, int row)
  float h = dht.readHumidity();
  float t = dht.readTemperature();
  // check if returns are valid, if they are NaN (not a number) then something went wrong!
  if (isnan(t) || isnan(h))
    lcd.setCursor(col,row);
    lcd.print("Failed to read from DHT");
   else {
    t=(9.0*t/5.0)+32.0;
    lcd.print("Temp: ");
    lcd.print(int(t));
    lcd.print(" F");
    lcd.setCursor ( 0, (row+1));
    lcd.print("Humidity: ");
    lcd.print(int(h));
    lcd.print("%");
}  //Endwritetemphumid
John_Smith
