Loading...
Pages: [1]   Go Down
Author Topic: ADK2012 audio output  (Read 934 times)
Offline Offline
Newbie
View Profile
I'm trying to extend the USBHost/ADK lib to ADK2012. I'm interested in the audio output. Basically, I want to know the audio latency of such a solution.
So far, I find the correct interface (audioIf=1) & endpoint. I set the correct device configuration "1" (I checked this) and try to select the alternate setting that contains an endpoint (alternate setting altSet=1). However, if I check the active alternate setting, I get a 0 back.
The relevant code:
rcode = pUsb->ctrlReq(bAddress, 0 /* control endpoint */,
      USB_SETUP_HOST_TO_DEVICE |USB_SETUP_TYPE_STANDARD| USB_SETUP_RECIPIENT_INTERFACE,
      USB_REQUEST_SET_INTERFACE, altSet /* valLo */,0 /* valHi */, audioIf /* index */, 0 /* total */, 0 /* bytes */, NULL /* data */, NULL /* read parser */ );
TRACE_USBHOST(printf("AndroidAccessory2::Init : set interface %d\r\n", rcode); )
if (rcode) {
   goto FailSetConf;
delay(2000);
      USB_SETUP_DEVICE_TO_HOST |USB_SETUP_TYPE_STANDARD| USB_SETUP_RECIPIENT_INTERFACE,
      USB_REQUEST_GET_INTERFACE, 0 /* valLo */, 0 /* valHi */, audioIf /* index */, 1 /* total */, 1 /* bytes */, &alt/* data */, NULL /* read parser */ );
TRACE_USBHOST(printf("AndroidAccessory2::Init : alternate setting set %d\r\n", alt); )
if (rcode) {
   goto FailSetConf;
I compared it with the code from the google ADK2012 download, but cannot find the difference/error. Any tips?
Logged
refined-apps.com
Offline Offline
Newbie
View Profile
The relevant code:
if (rcode) {
   goto FailSetConf;
delay(2000);
if (rcode) {
   goto FailSetConf;
Perhaps we just need common music player to output Audio via MicroUSB? What code do you use on Due side? I am also interested in Audio out via MicroUSB.
Logged
Offline Offline
Newbie
View Profile
On the due side, I hacked the USBHost lib that comes with the arduino ui.
In the meantime, I got audio out working (more or less) by following the instructions in http://arduino.cc/forum/index.php/topic,139279.0.html. Audio output still stutters slightly and latency is high (> 200ms).
I also checked the switch to alternate setting based on that version. It seems like the android devices switch but don't report the correct alternate setting.
Logged
refined-apps.com
Offline Offline
Newbie
View Profile
Why don't you just use ADK2012 IDE which already implement USB audio?
Logged
Pages: [1]   Go Up
Print
Jump to:
