Author Topic: labview+arduino BT  (Read 348 times)
i m getting error i2c_init was not declared in the scope while i upload the code for MLX90614, i follow the instructions given http://bildr.org/2011/02/mlx90614-arduino/
Pls help me
Austin, TX
CMiYC
To make this code work, before you load the code, or even open the Arduino program, we need to place the “I2Cmaster” in your Arduino Library. If you don’t know where that is by default, Look to the right.
Did you install the library?
www.cmiyc.com - A guide to being an Enginerd
Thank you sir, i done what you ve said, now the code is compiled but it showing that "Binary sketch size: 4,652 bytes (of a 28,672 byte maximum)" it doesnt show any value in my serial monitor. Actually i m working with ArduinoBT interfacing with MLX90614 IR Thermometer. Please help me.
Melbourne, Australia
Online Online
Shannon Member
Lua rocks!
now the code is compiled but ... it doesnt show any value in my serial monitor
What code would that be?
Austin, TX
CMiYC
Are you clicking the button that actually opens the serial monitor window?
yes sir, i clicked the actual button for the serial monitor, here the code is
#include <i2cmaster.h>
void setup(){
   Serial.println("Setup...");
   i2c_init(); //Initialise the i2c bus
   PORTC = (1 << PORTC4) | (1 << PORTC5);//enable pullups
void loop(){
    int dev = 0x5A<<1;
    int data_low = 0;
    int data_high = 0;
    int pec = 0;
    i2c_start_wait(dev+I2C_WRITE);
    i2c_write(0x07);
    // read
    i2c_rep_start(dev+I2C_READ);
    data_low = i2c_readAck(); //Read 1 byte and then send ack
    data_high = i2c_readAck(); //Read 1 byte and then send ack
    pec = i2c_readNak();
    i2c_stop();
    //This converts high and low bytes together and processes temperature, MSB is a error bit and is ignored for temps
    double tempFactor = 0.02; // 0.02 degrees per LSB (measurement resolution of the MLX90614)
    double tempData = 0x0000; // zero out the data
    int frac; // data past the decimal point
    // This masks off the error bit of the high byte, then moves it left 8 bits and adds the low byte.
    tempData = (double)(((data_high & 0x007F) << smiley-cool + data_low);
    tempData = (tempData * tempFactor)-0.01;
    float celcius = tempData - 273.15;
    float fahrenheit = (celcius*1.smiley-cool + 32;
    Serial.print("Celcius: ");
    Serial.println(celcius);
    Serial.print("Fahrenheit: ");
    Serial.println(fahrenheit);
    delay(1000); // wait a second before printing again
Have you got the serial monitor baud rate set to 9600 properly?
i m using arduinoBT , is this compatible with labview latest version
i m using arduino BT , is this compatible with Labview, if so means pls send me some example links
sir,
pls help me in my project, i want to transmit data from my arduino BT to labview, send me some example codes
Online Online
Shannon Member
Lua rocks!
Please do not cross-post. This wastes time and resources as people attempt to answer your question on multiple threads.
Threads merged.
- Moderator
Seattle, WA USA
Seattle, WA USA
Labview reads and sends serial data. The code on the Arduino is no different when the serial data goes down a wire or is sent using radio waves.
