Author Topic: Log Tag RFID to SD check Overload  (Read 248 times)
Hi all,
I trie to  log each reading from a RFID Reader ID-20 On a SD card.
To have a tree y keep the 8 first char to my Tag to name a created folder with a .csv file on it.
it work but when I insist with the the Rfid I've an overflow.
Init SD [OK]
Server is [OK] : http:// 10.11.12.1
********Setup [OK] **********
4B00DDBA/open.csv
 Folder exist !
4B00DDBA/open.csv
 Folder exist !
B00DDBA68444B00DDBA68444B00DDBA/open.csv
4B00DDBA68444B00DDBA68444B00DDBA68444B00DDBA/open.csv
A/open.csv
Error open file!
4B00DDBAsv/open.csv
4B00DDBA684444B00DDBAsv/open.csv
4B00DDBAsv
Error creating folder!
Error open file!
4B00DDBAsv/open.csv
4B00DDBA684444B00DD
 //====================== RFID
  while(Serial.available()){
    int readByte = Serial.read(); //read next available byte
    if(readByte == 2) reading = true; //begining of tag
    if(readByte == 3) reading = false; //end of tag
    if(reading && readByte != 2 && readByte != 10 && readByte != 13){
      //store the tag
      tagString[index] = readByte;
      index ++;
        if (cpt <= 7){
      tagStringFolder[index2] = readByte;
      index2 ++;
      cpt ++;
void checkTag(char tag[]){
// Check if the Tag can('t) open thie door
  if(strlen(tag) == 0) return; //empty, no need to contunue
// Concat
  if (!strcat( filePath, tagStringFolder)) {
            Serial.println("Erreur concat !");
            return;
          }else{
            strcat( filePath, fileName);
            Serial.println(filePath);
     if (!SD.exists(tagStringFolder)) { // -=newTag=-
  //================ New String ==============
  // *** En faire une Fonction New string a appeler apres Vérification
       if(strlen(tagString) != 0){
           Serial.println(tagString);
           Serial.println(tagStringFolder);
        if (! SD.mkdir(tagStringFolder)) Serial.println("Error creating folder!");
        if (!SD.open(filePath, FILE_WRITE))Serial.println("Error open file!");
     }else{
       Serial.println(" Folder exist !");
//      Si folder exist alors lire les droits
        if (SD.exists(filePath)){
          //openLock
          for(pos = 0; pos < 180; pos += 1)  // goes from 0 degrees to 180 degrees
            {                                  // in steps of 1 degree
              myservo.write(pos);              // tell servo to go to position in variable 'pos'
              delay(15);                       // waits 15ms for the servo to reach the position
      //closeLock
         for(pos = 180; pos>=1; pos-=1)     // goes from 180 degrees to 0 degrees
        }else{
          Serial.println("Error Opening File");
   filePath[0] = '\0';
void clearTag(char one[]){
//clear the char array by filling with null - ASCII 0
//Will think same tag has been read otherwise
  for(int i = 0; i < strlen(one); i++){
    one[i] = 0;
If anybody have an idea
Thanks.
UK
You need to only process the buffer when you have received the whole tag, and clear the buffer once you have processed it. This means you need a way to detect the start and end of the tag.
