sending a motion command over serial
Hello,
I am relatively new to arduino, so please bear with me. I have a stepper motor with built in motion control (IMS MDrive MDI23) I would like to control with my Arduino. Normally, the command set for the stepper motor is given over an open serial port on the computer. For example, to move the motor 5000 steps, the command would be "mr 5000" followed by a carriage return. My question is, how do I get the arduino to send out that kind of command? It would be a transmit only command i.e. there is no need for a receive command back. I just need to transmit the commands. Thanks
JOe
Something simple, such as:
Serial.println ("mr 5000");
What is the electrical interface - do you need to be a USB master, is it RS232 levels, is it simple TTL levels?
I used your suggestion of Serial.println("mr 5000"). When I open the serial monitor tool in the arduino software, I see mr 5000 print out, but nothing is happening with my motor. I am trying to communicate over rs485. I have the rs485 shield on the uno, but no luck. I am guessing it is a communications issue, but I'm not exactly sure how to proceed. Any suggestions would be appreciated. Thanks
You could post links to the hardware in question, and a schematic, so that guessing wouldn't be required. It's up to you.
