Topic: the benefits of cleaning optical sensors? (Read 985 times) previous topic - next topic
franklin_Pit
Hi guys,
Would you please help me with this question..
Q: The benefits of removal of dirt and grime around optical sensors?
I can say:
1/ If there is too much dust, it will break down and by keeping it clean the sensor will live longer.
2/ Higher sensitivity to light, and more reliable.
3/ If it damaged or broke down, it would probably cost you to replace your device or the whole system and to save your time as well.
4/ Ensuring high accuracy of data, and more efficient.
What else?
Any help you can give would be greatly appreciated..
Grumpy_Mike
I can only say I agree with point 2.
The others are a bit nebulous / wrong.
retrolefty
I would also add a caveat that 'improper' cleaning methods of optics could result is worst performance/damage then if no attempt at cleaning was done.
Lefty
franklin_Pit
#3
Jan 04, 2013, 08:25 pm Last Edit: Jan 04, 2013, 08:27 pm by franklin_Pit Reason: 1
thanks for response
actually, I've got these points by searching on the internet and I'm not sure, therefore I need your help to answer this question..
Grumpy_Mike
It helps to know what sort of optical sensor we are talking about here.
An image sensor, colour sensor, or light sensor.
franklin_Pit
the third one (the light sensor)
Grumpy_Mike
Well I would defiantly say just number 2 on the original list.
Dirt will act just to reduce the sensitivity.
