Pages: 1 [2]   Go Down
Author Topic: Measuring current above 10A  (Read 622 times)
Manchester (England England)
Solder is electric glue
What kit would you recommend to measure higher currents, up to about 40A?
http://uk.farnell.com/_/cp-09/probe-current-clamp-ac-200a/dp/1003036
http://uk.farnell.com/amprobe-instruments/ac50a/current-clamp-earth-leakage/dp/1466482
http://uk.farnell.com/fluke/fluke-902-e/current-clamp-hvac-fluke-902/dp/1895810
SF Bay Area (USA)
Strongly opinionated, but not official!
Don't forget that at 40A, your "test leads" will need to start looking like the cables used to jump start automobiles.  Standard house wiring (14g solid wire) is only good for about 15A...
Windy City
If the conductors are not double insulated (like Romex) and within the walls of house, #14 wire is actually rated at closer to 30 amps.  For 40 amps over short runs you could theoretically get by with #12 wire, but for sufficient safety margin, I'd go with #10 at least.
Dirt Biker
SF Bay Area (USA)
Could be; I was looking at the Romex specs.
Um.  Are you actually allowed to use not-double-insulated wire in your house these days (I guess the answer depends on where you live...)
Windy City
I think only if it is in an approved conduit or cabinet (or wiring box).  I think it's the same up in Canada.  My brother in law is an electrician in Ontario.  According to him the US and Canada have basically the same rules.
Dirt Biker
Online Online
What is the voltage driving the 40a? if it is low like 12v, then look to the automotive world for gizmos like below. Depending on the driving voltage, you should be able to make a shunt that would be optimized for the power that will be disipated and still with a decent measurable voltage drop across it. Also, what is the gizmo thru which the current is to flow (assuming you are not doing a dead short smoke test)?
http://www.harborfreight.com/100-amp-6-volt-12-volt-battery-load-tester-90636.html
put in key search words,
Pages: 1 [2]   Go Up
