Topic: Automated Reptile Control System(webserver, Data Logging, RTC and much more) (Read 115304 times) previous topic - next topic
Rextytus
Well, I just checked, and an example of the library sd card works without a problem. The only problem in this sketch. Have you tried this sketch and work for you?
nitrof
No. I didn't.
Maybe you should check if file use by the sketch is created by it or have to be already present on the sd card...
wallaceb
I am not sure what your issue would be. You said everything else works right, like the temp sensors etc?
I know I am using a slightly different approach to SD cards than the default example sketch. Obviously it is something to do with the project or the library implementation.
To my knowledge no one else has complained about SD card issue
