Topic: Automated Reptile Control System(webserver, Data Logging, RTC and much more) (Read 111457 times) previous topic - next topic
mkcinek
ps. what rtc module do you use ? I do not know why but I just can not start mine - it is Tiny RTC I2C module...
thanks!
Really appreciate your help and response!!!
Nick_Pyner
I have five of those, they cost a couple of dollars each, and they all work fine. I have heard that they must have a battery installed to work. I don't understand why, but somebody recently had a dud battery and that was apparently the problem.
mkcinek
Thanks, I will test the battery ( perhaps I will buy another RTC)
Would you have an idea when trying to connect with smartphone, arduino freezes - orange led starts blinking and no response...
Is there a way to use mobile devices with your control system?
Nick_Pyner
No idea, I don't have a smart phone.  My involvement is more about feeds to the internet and the only mobile device is a laptop getting the same data feed via bluetooth.
mkcinek
thanks for fast reply!
I wonder if there is anybody who has tried to connect to this sketch with a smartphone ?
Thanks !
wallaceb
hi,
thanks - manual moisture control works now.
I have encountered another issue, when trying to connect with smartphone, arduino freezes - orange led starts blinking and no response...
Thanks!
i have experienced this as well when using the stock android browser. i have to use Mobile Fire Fox browser and i have no issues when using my smart phone. i have not determined what the cause of this behavior is. Just use fire fox mobile and you should not have any problems. there must be some issue with how the stock andriod browser behaves that keep the sketch in an infinite loop within the client connected code.
the battery is required to keep the RTC module's time going when no external power is applied. otherwise the clock resets to zero.
thanks!
i just did a search on amazon for RTC modules.
mkcinek
hi, any idea why I am only getting Middle Ground temp reading although Cold and Middle sensors connected.
Two one wire sensors with 4,7k resistors on each.
thanks!
Nick_Pyner
You only need one 4k7 but I don't know if this is the cause of your problem.
wallaceb
thanks!
i honestly do not know. i myself have one 4.7k resistor per sensor as well since each data line goes to its own dedicated I/O pin. do you have the sensors connected to the correct pin? have you tried to make sure the sensors that are not working, work correctly when connected to the I/O pin of one that does?
mkcinek
thanks!
As far as I know one wire sensors are attached to 22,24,26, 28,30 pins.
Only getting Middle Ground readings, however after switching from Celsius to Fahrenheit I can get readings wherever sensor is connected, do you work on F or C?
thanks!!!
wallaceb
i keep mine in F the entire time. i just checked, and it is doing the same thing on my system when set to C.... i will have to look into what is going on.
wallaceb
found the issue
change the current code:
Code: [Select]
void CONVERT_TEMP(byte Sensor_PIN, byte & temp_whole, byte & temp_fract, byte & temp_status) {
  OneWire  dSensor1(Sensor_PIN);
  byte i;
  byte present = 0;
  byte data[12];
  byte addr[8];
  int HighByte, LowByte, TReading, SignBit, Tc_100;
  if ( !dSensor1.search(addr)) {
    dSensor1.reset_search();
    delay(250);
    temp_whole = 0;
    temp_fract = 0;
    temp_status = 0;
    badsensorcount ++;
    return;
  if ( OneWire::crc8( addr, 7) != addr[7]) {
      temp_whole = 0;
    temp_fract = 0;
    temp_status = 0;
    badsensorcount ++;
    return;
  // The DallasTemperature library can do all this work for you!
  dSensor1.reset();
  dSensor1.select(addr);
  dSensor1.write(0x44,0);         // start conversion, without parasite power on at the end
  delay(1000);     // maybe 750ms is enough, maybe not
  // we might do a dSensor1.depower() here, but the reset will take care of it.
  present = dSensor1.reset();
  dSensor1.write(0xBE);         // Read Scratchpad
  for ( i = 0; i < 9; i++) {           // we need 9 bytes
    data[i] = dSensor1.read();
  LowByte = data[0];
  HighByte = data[1];
  TReading = (HighByte << 8) + LowByte;
  SignBit = TReading & 0x8000;  // test most sig bit
  if (SignBit) // negative
    TReading = (TReading ^ 0xffff) + 1; // 2's comp
  Tc_100 = (6 * TReading) + TReading / 4;    // multiply by (100 * 0.0625) or 6.25
  if (temp_scale == 1){//if using degrees F, the celcius reading from the sensor must be converted
     temp_whole = (int)(((Tc_100)*(1.8))+3200)/100;
     temp_fract = (int)(((Tc_100)*(1.8))+3200)%100;
     if (temp_whole > 32){
       temp_status = 1;//if the temperature is above 32 degrees F, then the sensor is OK
     }else{
       temp_status = 0;//the sensor must be bad as the temperature must never get down as low as 32 degrees F, the snake would die!!
   }else{//if using degrees C, the temp reading is good as is.
     middle_temp_whole = Tc_100/100;
     middle_temp_fract = Tc_100%100;
     if (temp_whole > 0){
       temp_status = 1;//if the temperature is above 0 degrees C, then the sensor is OK
     }else{
       temp_status = 0;//the sensor must be bad as the temperature must never get down as low as 0 degrees C
to
Code: [Select]
  byte i;
  byte present = 0;
  byte data[12];
  byte addr[8];
    delay(250);
    temp_whole = 0;
    temp_fract = 0;
    temp_status = 0;
    badsensorcount ++;
    return;
      temp_whole = 0;
    temp_fract = 0;
    temp_status = 0;
    badsensorcount ++;
    return;
  dSensor1.reset();
  LowByte = data[0];
  HighByte = data[1];
     }else{
     }else{
wallaceb
mkcinek
It looks great, everything is organized as it should be - but where is the snake ;) ?
Have you update your code recently ?
wallaceb
the snake only like to come out at night  :smiley-sleep:
my latest will be uploaded later tonight. only a few small things have been tweaked, and i re-added corrected code so the RTC will update off NTP servers once a day.
