Author Topic: Need help on SoftwareSerial (+SIND:0)  (Read 355 times)
Dear All,
I am very new with Arduino and I am trying hard to understand a code wich read the serial port.
Could you help me on it?
My goal is read this:
if(cell.available() > 0){
incoming_char=cell.read(); //Get the character from the cellular serial port.
Serial.println(incoming_char); //Print the incoming character to the terminal.
        if (incoming_char == '\n') {
          Serial.println("[n]");
        if (incoming_char == '\r') {
          Serial.println("[r]");
        if (incoming_char == '\O') {
          Serial.println("[00]");
and to collect all data, in a array or varibale, such
+SIND: 1
+SIND: 10,"SM",1,"FD",1,"LD",1,"MC",1,"RC",1,"ME",1
+SIND: 11
+SIND: 3
+SIND: 4
(and other)
I also would like to Serial.print() the message matching to those code
0 SIM card removed
1 SIM card inserted
2 Ring melody
3 AT module is partially ready
4 AT module is totally ready
5 ID of released calls
6 Released call whose ID=<idx>
7 The network service is available for an emergency call
8 The network is lost
9 Audio ON
10 Show the status of each phonebook after init phrase
11 Registered to network
I also, I would like to run the GSM/GPS communication when +SIND: 4.
For now I found that code that I can not understand, or, let's say translate and explain to a human:
static void readATString(boolean watchTimeout = false) {
  char buffidx = 0;
  int time = millis();
  while (1) {
    int newTime = millis();
    if (watchTimeout) {
      // Time out if we never receive a response
      if (newTime - time > 30000) error(ERROR_GSM_FAIL);
    if (cell.available() > 0) {
      incoming_char = cell.read();
      if (incoming_char == -1) {
        at_buffer[buffidx] = '\0';
        return;
        continue;
      if ((buffidx == BUFFSIZE - 1) || incoming_char == '\r') {
        return;
      at_buffer[buffidx++] = incoming_char;
How is printed and stored the value of at_buffer[buffidx]?
In other word, I would like to have somethink like this.
if (something == "+SIND:0") Serial.print("SIM card remove");
if (something =="+SIND:1") Serial.print("SIM card inserted");
if (something == "+SIND:3") Serial.print("AT module is partially ready");
if (something == "+SIND:4") Serial.print("AT module is totaly ready");
if (something == "+SIND:10") Serial.print("message");
if (something == "+SIND:11") Serial.print("Registered to network");
Someone can explain me or provide me an exemple?
Many thank for your great help, I loat all my afternoon on this.... :o|
Cheers and happy new year!!
« Last Edit: January 04, 2013, 02:47:11 pm by pierrot10 » Logged
UK
if ("+SIND:1") Serial.print("SIM card inserted");
As you've probably already found, "+SIND:1" is always true.
You need to look at "strcmp"
Seattle, WA USA
Seattle, WA USA
// Here you need an else statement with a block that stores the character
// in the next element in an array
Thank for help, I understand a litle bit more.
I would really appreciate if you can help me to understand how work this and how the data are store in at_buffer.
I ma confused particularely with the \r (Line new) and \n (return) and \0.
How the loop run and at with step data are store in at_buffer....
  char c;
  char buffidx = 0;
  while (1) {
    // after 30sec it retun a error (not usefull for now)
    if (watchTimeout) {
      c = cell.read();
      // If not available .......
      if (c == -1) {
        at_buffer[buffidx] = '\0'; //?
        return;
      if (c == '\n') {
        continue;
      if ((buffidx == BUFFSIZE - 1) || c == '\r') {
        return;
      at_buffer[buffidx++] = c;
Is there not a print_r() to print at_buffer, like in PHP?
Many thank for your help
« Last Edit: January 04, 2013, 03:15:13 pm by pierrot10 » Logged
Seattle, WA USA
Seattle, WA USA
      c = cell.read();
      if (c == -1) {
If there is data to read, read the first character. How can you not have read something?
No, and why should there be? C++ allows for function overloading. The print() method can print a lot of different things, like ints, floats, bytes, chars, and, you guessed it, arrays of chars.
Hello
I have some big trouble to understand how work SoftwareSerial.
I understood that I have to add those line:
SoftwareSerial cell(GPRS_TX, GPRS_RX); //int GPRS_TX = 2; int GPRS_RX = 3;
Then I can run taht condition:
But now I have big difficulties ti understand how to store and work specialy with those value
+SIND: 1
+SIND: 3
+SIND: 4
+SIND: 7
+SIND: 11
I am trying to do something like this:
if (incoming_char == "+SIND:0") Serial.print("SIM card remove");
if (incoming_char =="+SIND:1") Serial.print("SIM card inserted");
if (incoming_char == "+SIND:3") Serial.print("AT module is partially ready");
if (incoming_char == "+SIND:4") Serial.print("AT module is totaly ready");
if (incoming_char == "+SIND:10") Serial.print("message");
if (incoming_char == "+SIND:11") Serial.print("Registered to network");
My goal is on myLoop() function.
Each 10 sec, it start the loop, check the GPRS connetion and display the error (or a red led), if there are errors.
I would really really appreciate if you can provide me some help. I am totaly lost.
I hope my post was clear, but feel you free to ask me question for more detail
Many thank
Your post definitely needs some clarity added to it (more of the code), and perhaps some of what you have tried?
The first thing you need to test is the result of 'incoming_char'- so Serial.print it. I bet it's not the string you are testing for, I'd suggest it's just one of the characters of the string you are expecting.
UK
Near-identical topics merged.
Here are more code
  pinMode(LED_STATUS, OUTPUT); //int LED_STATUS = 13;
  pinMode(LED_ERROR, OUTPUT); // int LED_ERROR = 12;
  pinMode(GPS_RELAY, OUTPUT); // int GPS_RELAY = 9;
  ////Initialize serial ports for communication.
  Serial.begin(4800);
  cell.begin(9600);
  //Let's get started!
  Serial.println("Power on");
  // Check LEDS
  blinkLed(LED_ERROR, 5, 25);
  blinkLed(LED_STATUS, 5, 25); // Pin, flashtime, delay
// Main Loop
  if (firstTimeInLoop) {
    firstTimeInLoop = false;
  readATString();
  Serial.println("Delay of 10 sec");
  delay(10000);
readATString is called and ...
const int BUFFSIZE = 180;
char at_buffer[BUFFSIZE];
//char buffidx;
char buffer[BUFFSIZE];
  char buffidx = 0;
  //while (strstr(at_buffer, "+SIND: 4") == 0 && strstr(at_buffer, "+SIND: 10,\"SM\",1,\"FD\",1,\"LD\",1,\"MC\",1,\"RC\",1,\"ME\",1") == 0) {
  int i = 0;
  while (1) {
    i++;
    Serial.print(i);
        Serial.print("--------------------------1");
        return;
        Serial.println("continue");
        continue;
        Serial.println("return");
        return;
    }else{
      Serial.println("toto");
      return;
... and I would like that at_buffer collect the code as +SIND+ 0, >SUND+ 1 etc in order to display the marching message, as for exemple
if (at_buffer == "+SIND:0") Serial.print("SIM card remove");
if (at_buffer =="+SIND:1") Serial.print("SIM card inserted");
if (at_buffer == "+SIND:3") Serial.print("AT module is partially ready");
if (at_buffer == "+SIND:4") Serial.print("AT module is totaly ready");
if (at_buffer == "+SIND:10") Serial.print("message");
if (at_buffer == "+SIND:11") Serial.print("Registered to network");
Is it no array in sketch?
I do not really understanf the readATString function, how the caracter are "compiled" in at_buffer.
I am very block at this point.
Many thankf for your help
« Last Edit: January 05, 2013, 08:01:53 am by pierrot10 » Logged
You aren't using an array with this line of code:
You were given a valid answer earlier:
What did you find when you looked into strcmp?
Yes I use it.
if(strcmp(at_buffer, "+SIND: 1") == 0 ) Serial.print("No SIM card").
But it does not help because I do not undertsand how work at_buffer. May be yoiu can correct my comment, here
  char buffidx = 0;
  int i = 0;
  while (1) {
    i++;
    Serial.print(i);
    // If available continue
      // add the first caracter to incoming_char
      // If there is no caracter, leave the function
        // This I do not understand
        // Leave the function
        return;
      // If caracter is a new line, continue
        // Continue to to top of the loop
        continue;
      // If bufidx is egal to BUFFSIZE-1 or caracter is return chariot
          //This i do not understand
        // Leave the loop
        return;
      // Add the caracter to at_buffer, at possition egal to buffidx and increment buffidx
       but if at_buffer is an array, I should read it like this
      at_buffer = {
      1 => +,
      2 => S,
      3 => I,
      4 => N,
      5 => D,
      6 => :,
      7 => ,
      8 => 1
      And I thin it would be easier to have this
 at_buffer = {
      1 => +SIND: 1,
      2 => +SIND: 4,
      3 => +SIND: 10
      //etc.
      // I think I need to clarefied it about at_buffer
Thank a lor for your help
« Last Edit: January 05, 2013, 08:37:45 am by pierrot10 » Logged
I am agree, I am confused...  smiley-slim
« Last Edit: January 05, 2013, 08:55:46 am by pierrot10 » Logged
You should add this to the code to get an idea of what is being seen:
    Serial.print(i);
Get rid of that, it's just giving you needless numbers (telling you it's looping).
Add Serial.println(incoming_char)
That'll give you a new line with the received character in Serial monitor.
The \0 at the end of at_buffer is a string null termination character.
