Author Topic: Arduino can't fade 2 LEDs at same time?  (Read 388 times)
Hello everyone, I'm trying to create an lighting effect with my arduino but I'm running into a bit of a problem. I have 13 LEDs hooked up in a row on my breadboard, connected to pins 1-13. The first led in the row is hooked to pin 11, and the last led is hooked to pin 2, which I understand to both be PWM pins. The effect I'm going for is for the first LED (hooked to pin 11) to start out at it's brightest, fade a bit, then the leds between the first and the last to turn on and off in order until they reach the last LED which brightens a bit, and so on, and so on until the first LED is off, and the last LED is at it's brightest, then it reverses going from last to first.
Whats happening instead is it works one way (from first LED to last), then when the order reverses the first LED just blinks on and off instead of fading up its brightness.
I'm new to C++ programming, so I'm wondering if I've messed up something in my code. Can someone take a look and let me know if they see anything that would cause this behavior?
int leds[]= {13, 12, 10, 9, 8, 7, 6, 5, 4, 2, 1};
int digLeds = 11;
int timer = 30;
int fadeLEDfront = 11;
int fadeLEDback = 3;
  for(int j = 0; j < digLeds; j++){
    pinMode(leds[j], OUTPUT);
  analogWrite(fadeLEDfront, 255);
  analogWrite(fadeLEDback, 0);
  // LEDs pulse front to back
  for( int fade = 15; fade <= 255; fade += 15 ){
    analogWrite(fadeLEDfront, 255 - fade);
    for( int i = 0; i < digLeds; i++){
      digitalWrite(leds[i], HIGH);
      delay(timer);
      digitalWrite(leds[i - 1], LOW);
      delay(timer);
    analogWrite(fadeLEDback, fade);
    digitalWrite(leds[digLeds - 1], LOW);
    delay(timer*3);
  randomLightShow();
  //LEDs pulse back to front
  for( int fade2 = 15; fade2 <= 255; fade2 += 15 ){
    analogWrite(fadeLEDback, 255 - fade2);
    for( int i = digLeds; i >= 0; i--){
      delay(timer);
      digitalWrite(leds[i + 1], LOW);
      delay(timer);
    analogWrite(fadeLEDfront, fade2);
    digitalWrite(leds[0], LOW);
    delay(timer*3);
  randomLightShow();
  ledsOff();
void ledsOff(){
  for( int n = 0; n < digLeds; n++ ){
    digitalWrite(leds[n], LOW);
//lights up LEDs randomly for random length of time
void randomLightShow(){
  int ranCycles = random(10,50);
  for( int r = 0; r < ranCycles; r++ ){
    int ranLength = random(1, digLeds);
    int ranArr[ranLength];
    ledsOff();
    //pick random LEDs
    for(int b = 0; b < ranLength -1; b++ ){
      int ranLED = random(0, digLeds);
      ranArr[b] = leds[ranLED];
    for (int j = 0; j < ranLength -1; j++) {
      digitalWrite(ranArr[j], HIGH);
    delay(timer);
    ledsOff();
Manchester (England England)
Solder is electric glue
What board are you using:-
On most Arduino boards (those with the ATmega168 or ATmega328), this function works on pins 3, 5, 6, 9, 10, and 11. On the Arduino Mega, it works on pins 2 through 13. Older Arduino boards with an ATmega8 only support analogWrite() on pins 9, 10, and 11.
Pin 1 is normally used for serial communications and should be avoided if possible.
Seattle, WA USA
Online Online
Seattle, WA USA
The Arduino can fade any number of LED at the same time. Not using delay(), though. That function absolutely, positively, has to do.
Read, understand, and embrace the blink without delay example.
It will, of course, require a complete rewrite of your program.
Arduino Uno, the diagram next to the pins says pins 11, 10, 9, 6,5, and 3 are pwm pins.
Ah, good to know. I'm going to take the LED out of that pin then.
Wait... so why does it work one way but not the other then?
« Last Edit: January 04, 2013, 04:38:35 pm by RaveCraft » Logged
United Kingdom
The simplified but not totally accurate explanation is that if you use delay, you can only do one thing at a time, because you can't do anything else while you are waiting for the delay call to complete.
Temple, Texas
The fact that it works "going forward" suggests your approach might work (if you are happy with how it is working "forward").
But, there is a bug in your "backward" code.  This is the correction:
    for( int i = digLeds-1; i > 0; i--){       // <<<<<<<<<<<<<<<<<<<<<<<<
      digitalWrite(leds[i-1], HIGH);          // <<<<<<<<<<<<<<<<<<<<<<<<
      delay(timer);
      digitalWrite(leds[i], LOW);              // <<<<<<<<<<<<<<<<<<<<<<<<
      delay(timer);
    delay(timer*3);
Cheers,
John
// Fade all IO by Osamu Iwasaki
// November 10, 2010
#include <MsTimer2.h>
#define OUT_MIN 0  // First pin
#define OUT_MAX 19  // Last pin (this includes the analog pins)
byte luminance[20];
byte lumi[20] = {};
 int i;
 for(i = OUT_MIN; i <= OUT_MAX; i++){
   pinMode(i, OUTPUT);
   digitalWrite(i,LOW);
   digitalWrite(i,HIGH);
   delay(150);
   //delay(50);
 MsTimer2::set(1, int_pwm);
 MsTimer2::start();
void int_pwm() {
 static int f_wait[20];
 static int f_max_time[20];
 static int f_speed[20];
 static int f_ct[20];
 static long f_interval[20];
 static int ch;
 for(ch = OUT_MIN; ch <= OUT_MAX; ch++){
   if(f_wait[ch] == 0){
     f_wait[ch] = f_speed[ch] + 1;
     if( (f_ct[ch] < 255) )
       if(luminance[ch] != 255)
         luminance[ch] ++;
     if(f_ct[ch] == 255){
       if(f_max_time[ch] == 0)
         f_max_time[ch] = 0; // On Max Time
         f_max_time[ch] --;
     if( (f_ct[ch] > 255) && (f_ct[ch] < 511) && (f_max_time[ch] == 0))
       if(luminance[ch] != 0)
         luminance[ch] --;
     if(f_ct[ch] >= 511){
       if(f_interval[ch] == 0){
         f_interval[ch] = 10 * random(100); // fading seed
         f_speed[ch] = random(100); // fading speed
         f_ct[ch] = 0;
         f_interval[ch] --;
       f_ct[ch] ++;
   f_wait[ch] --;
void fading(){
 static byte counter = 0;
 static boolean prev_off[20];
 int i;
   if(lumi[i] == 0){
     if(prev_off[i] == HIGH){
       prev_off[i] = LOW;
     lumi[i] --;
 counter --;
 if(counter == 0){
     if(luminance[i]){
       prev_off[i] = HIGH;
     lumi[i] = luminance[i];
void loop(){
 fading();
upload that and run it.
You sure can fade multiple leds, with delays.
Here is an example:
  time_mask=0x80;
  do {
    //fade led0
    if (dc0 & time_mask) digitalWrite(LED0, HIGH);
    else digitalWrite(LED0, LOW);
    //fade led1
    if (dc1 & time_mask) digitalWrite(LED1, HIGH);
    else digitalWrite(LED1, LOW);
    time_mask = time_mask >> 1;  //reduce time
    delayMicroseconds(time_mask); //waste some time
  } while (time_mask);
dc0/dc1 are duty cycles for led0/led1.
you can add as many leds there to fade.
