Loading...
Pages: 1 2 [3] 4   Go Down
Author Topic: motor code error  (Read 1028 times)
Global Moderator
UK
Offline Offline
Brattain Member
I don't think you connected the grounds, Dave.
View Profile
I know it is a bit late in the game, but do you have the grounds connected?
Logged
Pete, it's a fool looks for logic in the chambers of the human heart.
Offline Offline
Newbie
View Profile
yes
Logged
Offline Offline
Newbie
View Profile
i learned much of the basics now. Now I need to know How to send PWM through port 9 (because it supports PWM).
I found out that my if off when it is at 1500 and at full speed when it is at 2500. Do I need to use analogWrite or somehow be able to use the serial monitor or something else?
How do I set PWM?
Logged
Global Moderator
UK
Offline Offline
Brattain Member
View Profile
As far as the Servo library is concerned, all pins support PWM.
Don't think about using analogWrite with a servo or ESC.
Logged
Offline Offline
Newbie
View Profile
what do I have to do then ?
Logged
Global Moderator
UK
Offline Offline
Brattain Member
View Profile
I have no idea.
What are you trying to do?
What does your code look like?
What does it do that you don't want it to, and what doesn't do that you do want it to?
Logged
Offline Offline
Newbie
View Profile
I need the PWM TO BE 2500
zoomkat gave me the code below. It does not do anything but was the best help  I've had so far. he said that I put the values for angle milliseconds, etc in the serial monitor but when I do, nothing happens just my esc's beeps change each time i type in a number
// zoomkat 10-22-11 serial servo test
// type servo position 0 to 180 in serial monitor
// or for writeMicroseconds, use a value like 1500
// for IDE 0022 and later
// Powering a servo from the arduino usually *DOES NOT WORK*.
String readString;
#include <Servo.h>
Servo myservo;  // create servo object to control a servo
  myservo.writeMicroseconds(1500); //set initial servo position if desired
  myservo.attach(7);  //the pin for the servo control
  Serial.println("servo-test-22-dual-input"); // so I can keep track of what is loaded
  while (Serial.available()) {
    char c = Serial.read();  //gets one byte from serial buffer
    readString += c; //makes the string readString
    delay(2);  //slow looping to allow buffer to fill with next character
  if (readString.length() >0) {
    Serial.println(readString);  //so you can see the captured string
    int n = readString.toInt();  //convert readString into a number
    // auto select appropriate value, copied from someone elses code.
    if(n >= 500)
      Serial.print("writing Microseconds: ");
      Serial.println(n);
      myservo.writeMicroseconds(n);
      Serial.print("writing Angle: ");
      Serial.println(n);
      myservo.write(n);
    readString=""; //empty for next input
Logged
Offline Offline
Newbie
View Profile
ALL i NEED TO DO IS TO GET THE MOTOR TO SPIN
(i FORGOT TO MENTION THAT IN MY LAST POST)
Logged
Global Moderator
UK
Offline Offline
Brattain Member
View Profile
Quote
What do you mean by that?
You are entering numbers in the serial monitor, aren't you?
( when posting code, please use code tags, and please don't SHOUT)
This
Code:
if(n >= 500)
      Serial.println(n);
      Serial.println(n);
      myservo.write(n);
isn't really necessary; the Servo library does it for you - any value sent to the Servo write method greater than about 540 is automatically sent to the writeMicroseconds method.
« Last Edit: January 05, 2013, 10:25:57 am by AWOL » Logged
Offline Offline
Newbie
View Profile
lIm entering numbers like 1500 and 180,etc.
Nohthing happens except the ESC beeps. The motor does not spin.
It is giving really akward beeps now.
The capitals are accidental and I only realize it when it is too late
sorry for the long wait
Logged
Manchester (England England)
Offline Offline
Brattain Member
Solder is electric glue
View Profile
WWW
The link you posted to the ESC said that it was controlled by PWM. The servo library produces PPM (pulse position modulation). You need to find out more about what signals your ESC is expecting.
Logged
0
Offline Offline
Tesla Member
Arduino rocks
View Profile
The below is the ESC info. I think that there are too many possible issues that are currently beyond the OP's ability to sort out. the ESC beeps, so it apparently recognizes the commands. No telling what is going on with the wiring, power supplys and such. The OP may require some local help from a parent or hobby shop person to verify wiring and such.
Quote
Electric Speed Control (ESC) for Brushless DC Motors
For use with the ELEV-8 Quadcopter Kit.  ESC's are used on most RC equipment for controlling the speed of a brushless motor.  It is also compatible with a wide variety of 3.3 V and 5 V microcontrollers.  Compatible with a standard RC receiver or any 3.3 V or 5 V microcontroller running the proper pulse-width modulation (PWM).
Features:
Programmable with an ESC programming card so you don’t have to use your controller and count the beeps!
5 V BEC (Battery Eliminator Circuit)
High Current rating enables worry free operation of varying sized motors
Compatible with any standard RC receiver that you may have at home
Three-phase electronic control
Cells: 2-3S LiPo Input
Specifications:
Power Requirements: 7.4 – 11.1 VDC
Continuous Maximum Current: 30 A
Communication: PWM
Dimensions: 1.9 x 1.0 x 0.3 inches (48.26 x 25.4 x 7.62 mm)
Weight: 27 grams
Logged
Why I like my 2005 rio yellow Honda S2000 with the top down, and more!
GOOGLE ADVANCED FORUM SEARCH BELOW!
Go to:  http://www.google.com/advanced_search?hl=en
put in key search words,
use site or domain:  http://arduino.cc/forum
or in a google search box put key words site:http://arduino.cc/forum
Global Moderator
UK
Offline Offline
Brattain Member
View Profile
@ OP, I've just deleted yet another new post from you on this same topic.
Don't repeat. Last warning.
Cross-posting WASTES TIME.
Logged
Offline Offline
Newbie
View Profile
then  someone just help me
Logged
Global Moderator
UK
Offline Offline
Brattain Member
View Profile
Quote
Help us to help you.
If you start new threads, the people who helped you here may not read your new thread, so overall, you're wasting yours and our time.
Logged
Pages: 1 2 [3] 4   Go Up
Print
Jump to:
