Pages: [1] 2   Go Down
Author Topic: Atmega1284P @ 16MHz with 3.3V?  (Read 830 times)
I'm wanting to run the 1284P directly from lithium (4.2V peak, 3.7V nominal) with a LDO 3V3 regulator (dropout ~3.4V).  Page 325 of the Atmel datasheet (http://www.atmel.com/Images/doc8059.pdf) shows the speed grades for the chip.  My first question is to ensure I understand the graph correctly.  Since it's linear it seems like a simple cross-multiplication to get the exact speed at a given voltage.  If my understanding/math is correct...
2.7V @ 10MHz (given)
3.4V @ 12.58MHz (calculated for regulator dropout)
3.7V @ 13.7MHz (calculated for lithium nominal)
4.2V @ 15.55MHz (calculated for lithium peak)
The second question is that assuming the above is correct I understand I'll be overclocking a bit at 16MHz, especially as the batteries drain.  Has anyone else done this?  Maybe with a 328P and can let me know if things went well or they had problems?  I feel like I've read that people have done this without any issue but since this is a small-run commercial product I'm working on I don't want it to be unstable.
Any advice here is appreciated -- thanks in advance!
Massachusetts, USA
I'm confused.  Are you running the processor off the 3.3V regulator or directly off the battery?  If you use regulated voltage the battery voltage won't make a difference.
Yes, and it is not a problem, unless you are designing for NASA.
Anaheim CA.
Experienced old Whitebeard with a Full head of Hair...
@ *dhenry*... Don't quit your day job. Nasa?...
Bob
“The solution of every problem is another problem.” -Johann Wolfgang von Goethe
The clocking/voltage specs seem to be very conservative. I (and many others) have run atmega and attiny devices at 16MHz with 3.3V, for example, without any observable problems. Indeed, I've never heard or seen *any* report of a problem overclocking these outside of the datasheet specs.
I personally haven't tried running at a lower voltage than 3.3V at 16MHz, so couldn't tell you where the practical cut-off is. There must be limits, though, and although it is possible to disable brown-out reset completely by fuse settings, I wouldn't recommend it -- it could be coincidence, but the only 328p chip that has mysteriously died on me (even HV programming couldn't get a response from it) was one that I had completely disabled BO resets. I now routinely run BO reset at 2.7V for a 3.3V powered device.
« Last Edit: January 05, 2013, 04:46:25 am by pico » Logged
Manchester (England England)
Solder is electric glue
But note that running outside these parameters all bets are off regarding temperature range of the device, life time of the device, and reliability of the device.
Going outside published parameters is only what idiots do, like our dear henry.
Going outside published parameters is only what idiots do.
wimp smiley-wink
Rapa Nui
Pukao hats cleaning services
You may consider to set "Full-swing Crystal.." ("Full Swing Oscillator..") fuse to be on the safe side..  smiley-small
http://www.engbedded.com/fusecalc
« Last Edit: January 05, 2013, 05:14:58 am by pito » Logged
Belgium
I've run ATmega328's @ 16MHz @ 3.3V. One is connected to a nRF24L01 wireless module and a couple of I2C sensors. Have not had any issues.
« Last Edit: January 05, 2013, 06:05:59 pm by Bajdi » Logged
wimp smiley-wink
Idiot  smiley-wink
So have you tested this over the full temperature range, over the full voltage tolerance range. Have you tested the voltage thresholds of the inputs, the voltage outputs and loading. The propagation delays and all the machine op codes? How many samples have you tested?
No I thought not.
A simple functional test tells you absolutely nothing but yet beginners often think it is the be all and end all. It is not.
Belgium
For hobby stuff I see no reason to not try it. A crystal is easily swapped if it doesn't work. The downside is that when you run in to trouble you will keep guessing if it's the mcu that is acting strange or if your code is buggy. If I would make a commercial device I would stick to what the datasheet says.
Some people have no problem in selling boards that don't meet the specifications. I've seen a Chinese Arduino clone which has a jumper to switch between 3.3V and 5V and has a 16MHz crystal.
When I was a student I spent most of my free time overclocking cpu's using a LN2 setup just to see what the max frequency was. Some cpu's it was possible to run them at 1.5-2x the rated clock frequency, would only work for a couple of minutes though :p
When I last ordered some 16MHz crystals from Tayda I saw that they also sell 25MHz crystals so I couldn't resist and bought some  smiley-razz
Yawn smiley-wink
For hobby stuff...
Some among us like to fancy themselves as designers for NASA.
Upstate NY
If all you are going to be doing is to flash an LED on the Arduino board, then you can get by going out of spec.  Who knows or cares if it misses a flash or hangs up and does not work.  But if you are doing something serious like making an alarm system, replacing a controller for your dish washer or building a keypad to open your garage door, then you need to be exact and operate within the specs of all the parts you are using.
It is easier to do it right the first time than to figure out what is wrong.
Pages: [1] 2   Go Up
