Topic: Is it possible to convert a int into a string? (Read 920 times) previous topic - next topic
s3rr00
I am using a Seeed Studio TouchShield. I want to display an int on the screen. But the code only allows me to print chars and strings. I want to know if I can convert a int into a string or char. Basically what I'm asking do the following:
int=1, int=sting/char, string/char=1. Is this possible?
KeithRB
Sure, check out itoa()
http://playground.arduino.cc/Code/PrintingNumbers
s3rr00
guix
If the number is between 0 and 9 then you can do
Code: [Select]
char c = number + '0';
If number is bigger then no there is not an easier solution than itoa, but there is another solution that is sprintf
Code: [Select]
char string[12];
sprintf( string, "%d", number );
print( string );
Arrch
is there an easier way to do this?
How much easier are you looking to get?
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
