I'm having trouble getting my VS1053 to work with my Arduino. I was originally testing with an EtherTen (has onboard ethernet) but I moved back to just a plain Arduino UNO (to rule out any SPI conflicts/issues). The issue still remains.
Here's my set up.
I have an Arduino UNO, with a VS1053 (it says LCSOFT STUDIO; found a picture here:
http://www.siliconray.com/catalog/product/gallery/id/576/image/1462/ ).
I am using a terminal shield for ease of connection (
http://www.freetronics.com/collections/protoshields/products/terminal-shield-for-arduino )
I have a 5V and GND from the VS1053 going to the respective 5V and GND pins on the Arduino. I have a 0.25W 8 ohm speaker connected to the 3.5mm Jack, tested with my ipod and it plays sound; i have also tried different sets of headphones with the VS1053 too.
I have VS1053's pins:
XCS -> Pin D9
DCS -> Pin D2
DREQ -> Pin D3
XRST -> Pin D8
I have tried all sorts of code to get it to work, but getting right back to basics; I have two Sine Wave tests I found on forums and neither work.
They are:
http://pastebin.com/JwZqV8HQhttp://pastebin.com/Aju4w4QvThe Serial debug on the first one shows a loop:
starting sine test
exited sine test
starting sine test
exited sine test
as expected, but it doesn't actually play anything. The second sine test shows similar debug.
MIDI TEST
I have downloaded and tried the VS1053-master.zip library and accompanying MIDI example from github. Last night when I was testing it, I kind of got the Midi example doing something... It made sound (which was encouraging!) except it was just a Midi Crash symbol on a very very fast repeat (sounded like a punk song!) not a loop of instrument scales as it appears the code attempts to play.
Now, this morning with the same set up as far as I can tell, I can't even get the MIDI example to play any more. The serial console shows:
/var/folders/QE/QEEii8k6F3SF3XtoQfvzhU+++TI/-Tmp-/build3189860725521860600.tmp/rtmidi.cpp
FREE=1749
Booting VS1053...
VS1053 still booting
VS1053 Set
VS1053 Configuration:
00 MODE = 0x00
01 STATUS = 0xffff
02 BASS = 0xffff
03 CLOCKF = 0xffff
04 DECODE_TIME = 0x00
05 AUDATA = 0x00
06 WRAM = 0x00
07 WRAMADDR = 0x00
08 HDAT0 = 0xffff
09 HDAT1 = 0xffff
0a AIADDR = 0x00
0b VOL = 0x00
0c AICTRL0 = 0x00
0d AICTRL1 = 0xffff
0e AICTRL2 = 0xffff
0f AICTRL3 = 0x00
VS1053 OK
W 07: 8050
W 06: 0030
W 06: 0715
W 06: b080
W 06: 3400
W 06: 0007
W 06: 9255
W 06: 3d00
W 06: 0024
W 06: 0030
W 06: 0295
W 06: 6890
W 06: 3400
W 06: 0030
W 06: 0495
W 06: 3d00
W 06: 0024
W 06: 2908
W 06: 4d40
W 06: 0030
W 06: 0200
W 0a: 0050
+READY
MP3 HELLO WORLD
I have tried:
http://macauadventure.com/robotics/arduino/hello_world_2.pdeAND
https://github.com/dave5/mp3_test/blob/master/MP3_Shield_Example/MP3_Shield_Example.pdeboth of which have inline MP3 examples.
Neither of these have ever worked for me.
I'm kind of at my wits end here. Have I not wired these up correctly? Is the board faulty? Is there anything else I can do to test this?
I would love ANY help or feed back you can give
thanks!
