Topic: Arduino Mega 2560 R3 vs. Uno R3 for beginners {Raspberry Pi} (Read 71792 times) previous topic - next topic
zoomkat
Quote
Good point, but code runs rock solid on my Uno.
Does the *same* code run ok on the UNO with the LCD attached? No furture in comparing apples to oranges. From what I've read in this forum, hardware issues are somewhat rare, usually solder bridges, bent pins and such causing the boards to not work at all. Poor connections, bad cables and similar conditions succeptable to mechanical disturbance normally cause intermittent hardware issues. On ebay I use paypal and I've never had an issue getting my money back from a bad product.
Google forum search: Use Google Search box in upper right side of this page.
Why I like my 2005 Rio Yellow Honda S2000  https://www.youtube.com/watch?v=pWjMvrkUqX0
JamesD3rd
Quote
I never said he did, please re read what I said.
I was just trying to give a technical response to your non technical whine. Guess there is no good response to whines in a technical forum. As to ebay arduino boards, buy from vendors that have good feedback and have completed large numbers of transactions.
There is no reason to start acting like a child and insult people here.  You are not helping and are WAY off topic here.
If you want to help people solve problems with displays, there is a thread for that.
Nobody was insulting you when the topic of Chinese made Arduino's was brought up.
Maybe you need a time out to remind yourself how to interact with people.
zoomkat
Quote
Somebody lick the stripe off your candy cane?  8)
mishmash
Geez, can't anyone respond with a less than 30-second-read-response?  Cut to the chase!  Does Mega give better connections and connectivity than Uno so it's worth the extra buck or two? I use RPi w/Uno clone.  Works fine, but need more room for I/O, serial ports.
Wawa
mrred128
Because there are still people reading this thread.
FYI I have a Genuine Uno and a SainSmart Mega. Both are as reliable as I would expect.
The reality is these boards are mostly just pins-to-posts and there is not much electronics other than the cpu. If you are experiencing problems, it would be the chip. If you have a dip version, you can replace it.
What was not mentioned in this post is the Arduino platform normally does 5v logic, which is extremely friendly to the electronic hacker. I would never actually use a PI or variant to do any I/O, outside of pre-fab io. Connect your Arduino to a usb port and you have extended all the useful I/O you would probably need.
