Loading...
Pages: [1]   Go Down
Author Topic: Combine multiple char *  (Read 459 times)
United States
Offline Offline
Jr. Member
Indubitably
View Profile
Ok. This should not be complicated: I have an array of char pointers and I would like to combine the array into one char pointer. So for kicks, lets say I have this char * array:
Code:
char *chars[16] = {"a", "b", "c", "d", "e", "f", "g", "h", "i", "j", "k", "l", "m", "n", "o", "p"};
How do I combine these into the equivalent of
Code:
char *equivalent = "abcdefghijklmnop";
Logged
fuzzball27 >>-->
Global Moderator
Dallas
Offline Offline
Shannon Member
View Profile
WWW
Code:
char buffer[17];
for ( int8_t i = 0; i < 16; ++i )
  buffer[i] = *chars[i];
buffer[16] = 0;
Logged
Temple, Texas
Offline Offline
Sr. Member
View Profile
You could use
         String strings[]= { "abc", "d", "ef", "ghi" };
         String s = strings[2];
         etc
but there are caveats to using String, the most important of which I think is to make sure you're using a fixed "malloc" (      http://code.google.com/p/arduino/issues/detail?id=857#c8).
Cheers,
John
Logged
UK
Offline Offline
Tesla Member
View Profile
That's a curious thing to want to do. Just out of nosiness, why do you want to do that?
Logged
Offline Offline
Edison Member
View Profile
Code:
The answer actually depends on what exactly you meant by chars[] declaration.
As is, it is declared as an array of char pointers (aka an array of strings), and initialized as such. Except that they are initialized to strings consisting of 1 char (plus 1 null).
So if you meant it to be an array of strings that happen to be initialized to 1 char, none of the solutions provided so far will work.
If you meant it to be an array of chars, like:
Code:
char chars[16] = {'a', 'b', ..., 'p'};
then there is nothing to be done: chars is the pointer to a string.
Logged
UK
Offline Offline
Tesla Member
View Profile
That is incorrect. Coding Badly provided an answer that does exactly what was requested.
Code:
You have neglected to null-terminate the string in your example.
« Last Edit: January 05, 2013, 12:27:17 pm by PeterH » Logged
United States
Offline Offline
Jr. Member
Indubitably
View Profile
Well actually it's for a cocoa application to unlock a PDF, but I needed some low-level advice in a short amount of time, so I asked here smiley
I don't remember what I ended up doing (It's been a long weekend), but the program did what I needed and I'm done now haha
Thanks for all the help guys!
Logged
fuzzball27 >>-->
Pages: [1]   Go Up
Print
Jump to:
