Loading...
Pages: [1]   Go Down
Author Topic: programming attiny 85 error  (Read 621 times)
Offline Offline
Newbie
View Profile
Hi all,
i tried to program an attiny85 20mhz, and i receive the error message :
avrdude: stk500_getsync(): not in sync: resp=0x00
I followed this tutorial :
http://hlt.media.mit.edu/?p=1695
Can you help me ?
Logged
Brisbane, Australia
Offline Offline
God Member
View Profile
Hi
Reading the linked tutorial i only see support for the 1MHz or 8MHz internal clock sources on the ATTiny85.    What instructions were you reading for 20MHz?
The arduino-tiny cores support 16MHz with an external crystal.  I've read discussions of driving them faster but cannot recall whether arduino code was being used.
Geoff
Logged
Valencia, Spain
Offline Offline
Edison Member
View Profile
What did you do, exactly?
And what are you using to do it?
Logged
Offline Offline
Newbie
View Profile
I bought the attiny85 20mhz, tried to program them by following exactly the tutorial... and i have the error message...
Logged
Brisbane, Australia
Offline Offline
God Member
View Profile
Oh, sorry my mistake.
That error means there is no response coming back from the ATTiny.  Do you have the resistor or capacitor in place (depending on what arduino you are programming with)?
Did you get past the 'burning the boot loader' step okay, or is that where you are getting the error?
Geoff
Logged
Valencia, Spain
Offline Offline
Edison Member
View Profile
What Arduino did you use?
Logged
Denmark
Offline Offline
God Member
View Profile
WWW
Which version of Arduino IDE do you use. There has been some problem with ArduinoISP in  version 1.00.
You could try this modified version to see if it helps:
http://arduino.cc/forum/index.php/topic,108797.msg824488.html#msg824488  reply #39
Logged
Offline Offline
Newbie
View Profile
Geoff
i have a capacitor in place 10 uf and 22 uf, i tried both, burning bootloader doesnt work...
Logged
Dubuque, Iowa, USA
Offline Offline
Edison Member
View Profile
Pins 7, 8, and 9 output the status of ArduinoISP; use a ~500R resistor and an LED and they will flash based on the ISP status. Pin 9 is the heartbeat LED and will pulsate so you know ArduinoISP is running; that will verify that your caps are working to disable the reset.
http://www.forkrobotics.com/2012/04/run-arduino-code-on-an-attiny/
Logged
Valencia, Spain
Offline Offline
Edison Member
View Profile
Well...obviously you didn't. You did something differently.
If you don't start telling us what you did then we can't help you.
Logged
Offline Offline
Sr. Member
View Profile
The attiny85 can go up to 16MHz without an external xtal. The maximum 20MHz requires an external xtal, though.
Its just a matter of selecting the clocking fuse values appropriately. I run my attiny85 chips routinely at 16MHz, sometimes (more often than not, actually) even at 3.3V (shock horror! smiley-wink )
As long as the arduino core files are compiled for the 16MHz clock option, the timing functions will work correctly.
Logged
Brisbane, Australia
Offline Offline
God Member
View Profile
Thanks for setting me straight on that.  I just fired up the IDE and sure enough, there's the internal 16MHz option just above the one I typically choose.  All this time I'd thought that was an external flavour...I'm going to use male pattern blindness as my excuse.
Thanks again smiley
Geoff
Logged
Pages: [1]   Go Up
Print
Jump to:
